Scrambler on a budget
if anyone is a jeepforum member i could use a few votes for cj of the month august. that's if you think the scrambler is worthy of it.
thanks
today i decided to do the mechanical advance flip that jeephamer wrote about here http://www.jeepforum.com/forum/f8/working-your-distributor-how-tune-973904/
it was very easy however i recommend removing the dizzy to do anything to it. they are so easy to remove and install if you mark and remember how it came out.
mark the cap extender on #1 cyl .. remove the cap, crank till rotor points to #1. where you just marked it. remove the dizzy.
i always work on stuff with small parts in a box [ closed bottom LOL ] and a magnet!!!
mark the roll pin location and carefully pry the armature off. i had to remove the screws and e clip to make everything loose. this way nothing got bent.
remove the springs then the felt and the clip holding the advance arm in. here its in the stock 6.75 position
now its flipped to the 7.75 position and i also removed the plastic stopper on the arm
i cleaned it all up inside and made sure it didnt bind. i had some worn out stuff i had to remake but nothing serious.
i use RUG so i can only get 8 deg. advance. 10 deg it will ping badly but at 8deg i can be in 4th at 1k rpm, and floor it without any pinging. so its "safe" as jeephammer says.
jeep runs WAY better with all the mods i did this past 30 days but im disappointed that i didnt have a pre computer dizzy. i only got 1 degree mechanical advance. i'll look around the scrap yards an may get lucky on a dizzy. at least now you all know how to do it
i just filled it up and got 21MPG and thats with hammering it alot.
update: i found a pre computer dizzy. and flipped it to the 18R. now i feel that my engine is done till i save enough for a V=8 swap.. it is kind of nice now not having to downshift and go fast enough to say " maybe i should slow down " HAHAHA
next is bring on the AX-15 !
Haven't seen your jeep in a while , post up some new pics of that beauty please !!
here jim thanks. FYI i use this as my work truck too!!
i started on the AX15 this weekend. i got 98% of the greasy stuff off it with engine cleaner but that last 2% is the worst! i gave up....i decided why paint it; its a trans. its just going to get dirty again.
i didnt want any plastic parts on my clutch Mod.. Master cyl is stock CJ 4 cyl... Slave cyl i found a chevy truck one all steel with the same bore dia. as the Master cyl. and i can use old school steel line.. all it needed to line up was cut about 1/4 inch off the side and drill 2 new holes to mount it..
the old one i used as the reference point and used the old rod from it.
spray some paint in there to mark the proper hole locations for drilling.
all bolted up; i used some torx bolts from a red YJ..
i think it came out ok, i wont know until its bolted up to the engine block, i could be cursing alot.
Got a question... i will need about 2 inches removed from the length of the drive shaft from what i read. i was looking at a way to do this and was wondering if this is a possibility.
cut down this yoke the required distance so the splined end wont bottom out on it
Cut the tube-
i guess i will pay and have the driveshaft shortened, what sucks about that it is when the V-8 goes in the driveshaft will need to be longer than the stock shaft!!!
i got some much needed tail lights. the orig. were all clouded over and i felt unsafe during daylight hours.
i really wanted the savvy tails but they cost $300+ with the extras you need to do it right. thats why i never did anything about the tails till now...
i got very lucky and paid $13 delivered. from E-Bay FOR BOTH!!!! LED tail lights.. they work great and use the factory mounting holes...ebay had sent me a $25. coupon towards any purchase, SWEET! i wonder how long they will work?
hi all, after a long cold winter of storage and a few spring rides, i have started on the ax15 swap. im between jobs and have a week to get it going.
after unbolting everything this was the easiest trans. removal ever for me. i used a cherry picker through the tunnel and lowered it to the floor.
i will let you all know how the parts i researched and bought worked out.
when i clock the dana 300 up i want to replace the stock cross member so its about flush with the frame rails. does anyone remember a thread on this
my puppy cant wait to get this finished
