Scrambler UpGrades - Pappywaho
Wiring Harness
All i can say is that the painless wire harness was more VERY PAINFUL in my situation.
Keep up the good work. Looks like he will in the extreme group for Hot Springs this year.
I see the hi-lift jack spreading the frame rails- was your frame "pinched" in at the middle? Mine was...
Skid Plate (BEEFY)
Driveshafts ready for the machinist
Pap cleaning the tub. We are going to hose some bedliner on it.
A little fiberglassing to cover a few holes
Rock sliders will cover patching
Skid plate blasted the painted.
Removable u-joint access hole. (sometimes we try to think ahead)
We used a mixture or Herculiner and Dupilcolor bedliner. I think we sprayed 2.5 gals plus thinner.
Here are a couple pic's during application.
Buddy snagged me a Tyvec suit from his work to help keep the liner off of me.
We can't decide if I look more like the Michelin Man or the Stay Puff Marsh Mellow Man?
Looks first class! How did you decide on a mixture of the two bedliners? Is there a benefit? How about durability?
Another question... what did you spray it with?? I'm thinking a paint sprayer would get clogged with all the little rubber clods in the herculiner. Can you show a pic of your sprayer??
Mixture? No real reason other than I had some Herculiner on hand and the part store only 1 gallon of each (Herculiner & Dupli-Color). The Dupli-Color really didn’t have any texture when we applied it by itself. I had sprayed some Herculiner before and really like its texture so we just decided to mix the two so we could get it done. The mixture seems to setup pretty hard and it does look really good, IMO.
tinymay said:
Another question... what did you spray it with?? I'm thinking a paint sprayer would get clogged with all the little rubber clods in the Herculiner. Can you show a pic of your sprayer??
Air Undercoating Gun with Bottle and if the liner material is not mixed thoroughly it is possible to plug it as well.
I think I got it from Eastwood awhile back.
Just checked and they have them on sale for $11.88 + the ride.
http://www.eastwoodco.com/jump.jsp?itemID=1126&itemType=PRODUCT
Another good thing to use is a Ceiling texture gun that you can get a Northern and Harbor freight fairly inexpensively.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2471
There is an example of what I am talking about.
Just be sure that you keep the mixture well stirred up. You want to keep those big granules in suspension so that you get an even texture.
Carl
Looks great, liner looks like it came out very nice, inspired me to use the bedliner under my tub also. Can't wait to see it finished.
Thanks fellas!! :cheers:
I'll be shopping shortly. My tub needs a liner real bad. Every little pebble sounds like a bullet on just the sheet metal. Gravel roads at speed are full automatic fire!! Shooting a liner on it would be a GREAT improvement.
Thanks again for the tool links. I'll post some pics after I get going.
Trying to finish up wiring the dash.
Added some new gauges and a couple switches for lights and electric fan.
Will also add a fuse bus and some relays.
Hey....that drivetrain assembly looks familiar!:evil: Glad to see it will live to push another 8 up some hills!
Looks good fellas!
