Seatbelt Hack
Buckle sleeve: http://www.quadratec.com/products/14247_9202.htm
:shrug:
old shop vac attatchments. I was too cheap to lay out the $50 too. These were free.
Might want to do a looser zip tie or swap that out for some type of elastic strap/screws. If you stop suddenly or hit something (God forbid), even if minor, you'll have the belt wanting to rip out the zip tie at the least or the console at the worst. May also allow too much give in the belt system in the process, allowing the person to move too far forward once the belt pulls taught. Just my thought from doing my aftermarket console that has elastic straps with eyelets in the end to serve this purpose.
Shop vac attachments for the win!
On the console I built, when I still had the old-style buckle sleeves that were stiff except at the bottom and flopped whenever the seat went forward, I screwed some nylon webbing to the console in a similar fashion to the zip-ties. I gave it enough slack that the belt could still be pulled tight at any seat position adjustment. It worked perfectly, but still required a buckle sleeve to be effective due to the amount of slack; it's purpose was to keep the sleeve upright only when the seat went forward.
