Small block ford swap
Wait I just realized how terrible Ford's internal slave setup is. Well at least their master cylinder on the ranger platform. Have to remove it and the whole plastic line to bleed it properly.
I've been researching this for a while and may try it some day myself. I'd probably use the CJ master and adapt it to the Ford slave. Set the motor forward an inch or so and use a CV rear axle. Should be doable on paper at least.
If I didn't have my adapter and t18 rebuild kit on order I'd look more into it. The adapter itself is cheaper by about 250$ I assume the trans is a lot lighter being an aluminum case. I feel the close ratio diesel zf has a better spread of gears in it. I think a 4.5 first then a 3.x second. The standard one is a 5.4 followed by a 3.09 or something like that. I had a 2wd behind a 300 6 in a 96 250. I still used first gear with 3.73s and 235/85r16 tires. It wasn't terrible but it was a quick gear change especially with the 300. I wish I still had that truck. Don't sleep and drive.
Sand blasted my t18 case the other day and find it's got a crack in the case. Goes from the input bearing around the corner of the case. Not sure how that would happen. Bellhousing has no cracks. The input shaft is straight. Well at least I got a flywheel and bell housing from it. Now I'm looking for another one. But this has me almost considering that zf5 swap. I wish novak made an adapter like advance adapter does.
That stinks. I am not sure I would trust a weld on cast iron from a bearing surface around to next corner. That is a bit much.
The zf is also about 3 inches taller. You would need a body lift and/or get pretty creative in floor cutting and tunnel cover making to cover the shift tower, and may need a skid plate mod for a decent mount solution.
Some folks don't like it, but for light duty use like you said you are planning, the m5r2 from an f150 or bronco of that same era would be half the cost of a ZF and is notably smaller. Though it would still have the same shaft compatibility to the D300 and overall length issues as the ZF.
Sharing some thoughts: If you own the t18 adaptor set, another t18 or an np435 will be cheapest/easiest to fit.
If you can return the t18 adaptor:
- Next easiest would be a T176 if you can find one. No bell adaptor or transfer case adaptor required. Likely wouldn't need driveshafts either.
- Next would be an AX15 or NV3550 as the tranny to bell adaptor is $250 including the clutch disc, and a transfer case adaptor can be optional. And you likely wont have to change driveshafts.
- Next would be one of these ford transmissions as bell is integral, but you must buy the shaft adaptor and mount ring for transfer case for $300. And you will definitely swap driveshafts and cut up your floor.
Those were my considerations. I picked the ax/nv route because I wanted a low first gear and overdrive, I wanted it to shift well, the trannys are easy to find, easy to work on, and they are very nearly a factory fit.
Transmission price wouldn't be a problem. I'd get one from one of the u pull it yards I visit. All the same price. How much body lift do you think it would need? I've got to get new body bolts anyways and was thinking of going 1" I've personally broken a m5r2 so I don't really want that again. I kinda like the idea of od now since I'd like to drive it to Alaska from ny someday. 4400 miles is a bit much for a 4 speeds 1:1 even though I'd probably only use it 35% of the time. Maybe a 1" bl with a transfer case drop would help keep drive line angles in check and make it fit.
I have never put a zf in a jeep, but I have done a couple in old broncos. I have done nv3550 in old broncos and now in a jeep too. So, lets compare.
Here is a zf in a bronco:
Here is a nv3550 in bronco:
You can see that the zf tower (without shifter base) is 2x the size and comes up very near the downslope in bronco floor. The nv tower is smaller and comes up in the middle of flat floor section between seats.
In Jeep, the NV comes up at the VERY back edge of the stock floor opening. If it were 1/4 inch further back I would have had to cut the tub floor. Extrapolate that, and the ZF should come up near the front end of stock floor opening. But the tower is longer and wider and taller. So maybe it needs trimming on front end... maybe not. Will surely need more than the smooth curve cover that is stock on floor in jeep unless you find a REALLY big shift boot.
And I have never put a D300 behind a zf either....So I am not sure if/how the front drive shaft would clear.
Hope that makes sense and helps....
a 1 inch body lift would probably keep you from cutting any part of the actual floor at the back part of the tranny cover opening to fit the zf in. But the front will be a maybe still. And you will definitely not have a "flat" tunnel cover anymore unless you use a real big shift boot to seal up the floor.
Sorry about this part in above post. It was some of my initial thoughts before I figured out how to use pictures to tell the story better.
I really need to figure out how to edit posts....
Those are some great pictures for comparison (even with the Bronco tunnel). Is that at Dana 20 twin stick in the first photo? Thanks for sharing.
It is a D20 twin. That was on a "J" pattern d20 so putting on twin sticks is about the same as putting them on a d300. The "T" pattern d20 is a bit more work to twin, hence the "custom" Hurst handle mod.
I'll probably just find another t18. If I find I need to lower my highway rpms I can always get bigger tires. The scrap metal rush a few years ago cleared out a lot of the older trucks with the 18/435 in them I wish ford had some better 5 speeds that weren't so huge.
Good score today. A guy I know with a small junkyard has an 84 f250 with the 300 6 and a t18. He said it was a friends truck. Bought new in 85 and only 70k on it. But about 200lbs of metal missing from rust. I made a deal for 100$ for all the parts I want and he keeps the leftovers. Good for both of us since he got it for free anyways. Going to flip it upside down, cut the motor and transmission mounts, and then pull the engine/trans/t case out.
Got my new t 18 stripped down and ready for rebuild/ adaptation. Just sand blasted and painted the case. I also got a set of gt40 heads for my 351. I'm ordering a new cam next week. Xe258hr. I found a similar build that used the same cam and put out 310hp/400t18. I think the only difference was intakes and possibly headers
Gt40, or gt40p? Either is nice, and an improvement over what would have come on either block you have from factory. Plug angle is biggest difference between the 40 and 40p, but it can affect what headers you need.
Is it the 258 cam with 1300-5300rpm range with .533 lift? If so I have been around that one before and it is a good cam for a mild power pick up without making engine fussy. You will likely have to change valve springs even if you use stock rocker arms, but it is worth it.
And with that cam it doesn't matter, but you were sticking with carb over efi, right?
I've got both 40s and ps. I put the ps on craigslist but people keep asking for 40s. I got an offer of 300 I might just go for. I picked up a weiand stealth intake and a 600 holley.
The 40p's are a bit better I think, other than the header issues. They have a slightly smaller combustion chamber, no thermactor ports to mess up flow or quench area so you get slightly higher compression without detonation with them.
Their second weak spot is valve springs, but you are going to have to change those with the 258 cam whichever set of stock heads you use.
They are not cheap, but these headers would work on a jeep and clear the tranny/clutch you want to use:
http://broncohut.com/collections/engine/products/bronco-headers?variant=1208852289
