SOA kit?
I've never used their products but would recommend you look at welding up new spring perches instead and outboarding your spring hangers if needed. Is there a reason you don't want to weld something up?
I bought a rolled YJ that had that kit on there. It looked pretty good. He said that it flexed well and he liked it.
If it works, that would help with the geometry of doing it by hand. If it checks out I might try in with the scrambler I'm building.
I will just speak for myself, i have no first hand experience, but from what i see, I would not buy or ride in a Jeep with that kit.
Spring overs are complicated to truly do right, it's simply not something you can bolt on IMHO.
Sent from my iPad HD
Actually, I think it did roll because of the lift. He was spring over, with the stock YJ springs. He was driving down a small inclince, when his front tire dropped into a hole. The suspension was high and soft. The Jeep rolled over a few times, low speed.
The quality of the kit was good. If your not good at welding, you just bolt it on.
Reviews on the internet focus on bad customer service and to weld the kit to the axle (in case something comes loose). The welding sounds like a good idea, the bad customer services is what worries me.
I bought from this company, but I didn't buy the entire kit. I purchased the wrangler spring conversion brackets and then bought new perches and a high steer kit from ruffstuffspecialties.com. I haven't had an issue with mine at all, but my perches are welded in. Any vehicle has the potential to hit a major pothole on the road and damage something or break something loose, so a jeep offroading has a high potential for disaster with that kit I'm sure. It's a lot cheaper to go the route I did too.
X2 on the iffy cutomer service
