- Dexter
- MI
Now that I have a usable garage that my LJ actually gets to live in at night, I've been running with the top down or top up/windows out A LOT
It's GREAT!
Only issue was that I didn't have anywhere good to put the windows when they were out, they typically ended up across the hood of the Scrambler, and I imagine I've scratched them some moving them on/off there.
I hang the hard top from the ceiling when I go to the soft top and it got me thinking about doing something similar for the windows to the soft top. Whatever I did had to be easy enough/quick enough to use that I'd actually do it rather than toss the windows on the Scrambler.
This is what I came up with... It's two pieces of furring strip, some #8 screws, washers and nuts with some spring loaded utility clamps, screw hooks, rope and pulleys.
To deal with all three windows, I needed three sets of clamps and so I attached three clamps on each side of the two strips and then sandwiched two additional clamps (for the back window) between the two strips. The screws that connect the two strips are what secure the middle clamps and the six outside clamps got their own screws/nuts.
Two screw hooks in the ceiling, two in the top of the strips, some rope and a couple of hooks in my utility shelf for tie-offs and it's good to go. I cleaned out the store of spring clamps, 6 of them already had holes in them to use to mount them and I had to drill holes in the middle two.
This way none of the windows rub, it's real simple to clamp the windows on/off and I can secure it up for storage and down for loading/unloading the windows. It's mounted right behind where I park the LJ so it's actually faster to do than throwing the windows up on the Scramlber hood and it's much safer for the windows. There's enough space between them that they don't rub together
I was really happy that it worked out like I'd planned in my head. The only thing is that it takes one hand to steady them on the way up or down so they stay level, but that's simple.
Pics:
In the stored position:
Showing the way the strips are connected and the clamps mounted.
Closeup of two of the clamps at the end for the side windows and one in the middle for the back window (the back window isn't as wide, so those clamps are closer to the middle, which makes them all easy to get to):
It's GREAT!Only issue was that I didn't have anywhere good to put the windows when they were out, they typically ended up across the hood of the Scrambler, and I imagine I've scratched them some moving them on/off there.
Pics:
