- Landing
- NJ
I sold my other scrambler and am in the middle of delivering it to Blacksburg, VA, abut 475 miles from home. Since there have been some flat towing talks on these boards, I figured I would share my setup.
I made this tow bar about 12 years ago specifically to tow CJs...its an OEM CJ bumper shortened on each end and the triangle part is from an old snowplow frame, and then a 2" coupler bolted and welded on to that. The bumper part lines up to the original bumper mounting holes and is attached with 4 grade 8 bolts. An extra chain wrapped around any place that could fail gives added piece of mind.
This setup has carried many a CJ home, and has served me well before I got a car trailer. The setup works great, unlock the steering wheel, disconnect and suspend the driveshaft, and the scrambler tracked behind perfectly 400 miles so far and no issues. Keep plenty of stopping distance in front of you of course, and just drive safe and attentive.
My experience with this setup is everything works as it should...unless you dont have enough weight on the front...a few times I have towed frames or jeeps without motors...and then its a little squirrley.. Also have towed lifted 7s before too...but you need to make sure you adjust the hitch ball height to match or that will also lead to tracking and squirrely problems..
I chose this route for this haul because my 96 XJ (with 215K on original engine/trans/clutch) gets 21 mpg without a load behind it, and it is also my DD and most reliable ride...and cause I wouldnt have to drag a trailer home at 13 ish mpg each way... For most towing jobs and definately anything really nice I go to my car trailer and a truck...but for times like this...or for going to check out a CJ and not wanting to pull up with a car trailer behind me too...i have this.
A few pics from this morning, and now in Buean Vista, VA:
DSC05621 by jerseyjeeps, on Flickr
DSC05623 by jerseyjeeps, on Flickr
DSC05629 by jerseyjeeps, on Flickr
