- Biloxi
- MS
Took some of the top parts off the carburetor so I could remove and clean the idle tubes.
Reference picture for me:
Took this top plate off to take a look, everything moving freely, no debris in here, looks OK.
Take these parts off:
Then you can get to the idle tubes.
Two screws and the entire venturi cluster comes out.
NOTE: I also removed and reinstalled the little check ball to blast out a few more ports with carburetor cleaner. Be careful with this, very easy to drop it down into the intake/engine!!
Using torch tip cleaning kit to check/clean the idle tubes for obstructions.
Blast carburetor cleaner through the tiny port inside the big circle. One for each tube. This is how fuel gets inside the brass tubes.
Blasted out all the little ports in this part with carburetor cleaner, too.
Make sure to reinstall the little check ball before reinstalling the removed parts. Be careful!!
Then reassembly.
Then reassembly.
