- Biloxi
- MS
And just for @bigwalton, not a tree, but close, @Bad Karma favorite Harbor Freight trailer/ mobile paint booth!!!
Primed and painted the plate, because it just wouldn't be a Spankrjs project without painting something!!
Back to the proportions valves last stuck fitting, bolt cutters to cut the line.
Used the press as vice to hold the valve, drove a six point socket over the fitting, it backed out easy enough with a 3/8 ratchet, happy dance!!
Cleaned off the exterior of the valve, and blasted out the inside of it with Brake Parts Cleaner.
Removed both front rubber brake lines.
Easy enough to remove the driver side front hard brake line, the shorter of the two front hard lines.
