spare tire carrier adapter extender.
scott anderson
Old age Mutant Ninjaneer
Paragould
ar
I designed these this week...if this post violates any rules, remove.
I just thought this was a great idea and wanted to share. 4x4 hardware sells these for $49 and they only have one bolt pattern on them
Very nice. I have one of the Olympic tire carriers (it is missing the tire mount). Looks like I could bolt (or weld) this on and be good to go. How much???
I am trying to get $20..i have to have the pieces laser cut
Fudd said:
Nice... will it fit an 8 lug wheel?
yes but the holes would have to be drilled larger for the larger bolts...it will fit 8 on 6.5..which is all but the new fords which are metric
If you'll do one of those for $20 I'll take one. I don't even need all the extra holes, just stock location so I can put the full size spare on the rollbar mounted tire carrier.
Count me in too. If it is easiest, I will take it stock. If it can be custom, I may need the extention part longer...let me know...
just let me know what u want..i got so more plates burned today..so i am good for about 5 more if there is demand
Will it do 5x4.5? (I know, I know...) I have a tire carrier for the XJ that's useless because it's defective or was sent with missing parts.
They don't make the carrier anymore to get a replacement and I need a plate with lugs/bolts to weld to what I have to make it actually work...
I really would only need one of the endplates, not the whole thing.
If it won't do it as is, it's probably easier for me to just fab something up myself, but I thought I'd ask. Happy to support a Scrambler brother :D
Actually, what I'd like is to get a whole one just unassembled... the other plate might be useful to do one for the Scrambler later....
Ha, I got one of these from you in 2006 and just got around to putting it on the Scrambler Wed of this week.
Won't really need it once I get around to mounting that bumper/ tire carrier combo you made me, but it will work in the meantime.
I'll take one Scott for an 8 lug wheel, old Ford (78-79).
Send me your info, with shipping costs to 01835, I'll get the $$ out next week.
i need to know how long you want the tube in the middle to be..and i also want to tell you that the new design has round mounting plates instead of triangular..
the price is the same $30 bucks shipped..i use a flat rate box so it is the same everywhere.
Not sure how long the middle tube should be. I suppose it depends on wheel backspacing. I'm not sure what I'll be running for wheels yet, so maybe I'll wait and talk to you later about it.
sounds great..because u want it as short as possible...i would rather get it right the first time..generally 2 inches is long enough..but if u run hummer wheels it may need to be longer than that..because of the large back spacing
