Specs
breckwrecking
Narrow Tracker
Kittery
ME
About to go pick up my first scrambler tuesday and just wondering if you guys knew what axles, and gears came stock for the '83's. Is it standard jeep with the d-30 front and 35 rear? With just the 3.73 gears? What would the stock splines be?
It's an AMC 20 rear, not a 35. The gears varied quite a bit. If it was a 6 cylinder, there's a good chance it has, or had, 2.72s. Other ratios were available as well - 3.73 were in some, and the 4 cylinders usually had 4.11s. However, it is a CJ and it is almost 30 years old, so these things have a way of getting changed.
He was also asking about spline counts. I too would be interested in what the standard spline counts would be front & rear.
me three..
got a chance to buy a set of NIB Yukon 1-piece conversions for my 83 with AMC20 here locally and they are WT 29 splines, not sure what my spline count is..
Those shafts should work for you.
