Spring Replacement
Gscram
SOA Board Member
Brandon
MS
I have decided to replace the original suspension on my '82 CJ-8 with a Skyjacker 2.5" lift with Nitro Shocks. I need to replace the bushings in the shackles. My question is should I go ahead and replace the shackles now and if so what do you suggest?
Definitely get greasable bushings and shackles.
I thought that would be the way to go. Any suggestions on the shackles? This is a daily driver that only gets on trail rides a couple of times a year, National Event being one of them. Any comment on "Revolver" shackles?
My personal experience with greasable shackles has left me unimpressed.
It seemed to me that the bushings wore out just as fast. I am now running 4" Eye to eye shackles that I made myself from 1/4" plate. The rear shackles I have are revolvers, if you like lots of droop in your suspension Revolves work well, however they do have their drawbacks.
I'd say get the M.O.R.E. Greasable shackles since they are easy to come by, a little overpriced for what you get but a good quality shackle. Then just run what-cha got.
If you need more flex and such look into the revolvers or other suspension options.
Good luck!
Mark
Another thought...you may wnat to get greasable main eye bushings and put them in at the same time. The biggest reason for the greasables. to me, is less squeaking in the suspension. I hate squeaks and rattles.
Make sure your Springs & Shackles work well together
I wouldn't get too far ahead with the Shackles until you decide what kind/brand of lift you are going to go with. If you get a lift that has military wrapped springs like a BDS (which I personally like) you want to make sure your shackles fit okay.
My shackels I think are Dystar and are zero additionally lift but have a middle bolt for strength. The middle bolt is sleeved and with the military wrap of the BDS they were hitting. I removed the sleeve on the cross bolt on the shackle and it works fine now.
If I had bought shackles that had a fixed/welded cross bar I would have had to buy a different set for the BDS springs.
I broke both the stock shackles and spring hangers. I went Currie all the way around and have been impessed so far. Got their Slickrock Hangers and Greasable Shackles. I grease em up 1 time a month or so. I can smash them on rocks or logs without fear of them breaking.
I used the Currie tow shackles. They do have zerk fittings. The main attraction was that I could get towed home easily when needed. Not that my Jeep was unreliable- just unpredictable(yes there is a difference).
Best of luck.
Kyle
That's a good setup. Just put one on my CJ5 and the ride is great. Want to lift my 8 but need to change gearing first and that's more than I can handle. The 2.73 gearing is just to high for 33's. I put new stock shackles on at same time.
barryb
The greasable bushings have *nothing* to do with longevity of the bushing...they're still the same poly material. The difference is that it helps control squeaks, helps keep the suspension flexible, and helps keep the bolts and sleeves from becoming one. I will never run a rig without them. Currie & MORE are the most common. Not a bad idea to replace the weak factory hangers...the Slickrocks are actually made by JKS and Currie & MORE remarket them, price seems to be consistent among them.
