- Claflin
- KS
I just acquired a STC half soft top with no hardware that attaches to the tub with the rails. I currently have a STC tonneau on the same Scrambler that uses the rails too. I also just purchased a full length STC soft top with zip out windows and uses the rails to attach as well (thanks ttrdiablo!). I want to be able to switch from running the full length soft top to the half soft top with the tonneau cover easily.
Since the Specialty Top Co half soft top didn't include any of the hardware I plan on using a portion of the rail system from the full length soft top since I won't be needing some of it due to me already having most of the same rails from the tonneau cover hardware. The front bow assembly and hardware does appear to be slightly different between the full length soft top one and the one used on the half soft top (half soft top bow is angled at the bottom of the tub and the front bow bracket has a way to lock the bow in place where-as the bow on the full length soft top is perfectly straight and the bow mounting bracket does not lock). These can be seen on page 3 of the first link to the half soft top installation instructions and page 4 in the second link for the full length soft top installation instructions. Can anyone confirm this or will it work regardless of which bows or mounting brackets I use?
http://www.thejeep.com/kayline/instsheets/108241.pdf
http://thejeep.com/stc/instsheet/108211.pdf
I am needing to know the length of the rails that attach the half soft top to the tub as well as the rails that attach the back portion of the soft top to the bulkhead. Pictures of this hardware attached to a Scrambler as well as the rear window hardware would help too! The rails I am referring to are item #6 and #15 in the attached link: http://www.thejeep.com/kayline/instsheets/108241.pdf
Also, will I need to leave a small section out of the rail system to allow me to switch easily between the half soft/tonneau cover combo over to full length soft top; or will using a continuous belt rail along the entire side of the tub work? In the picture of the Scrambler from the old STC site, you can see a small "gap" between the front edge of the tonneau cover and where the soft half top attaches to the side of the tub.
If anyone has pictures, measurements, or suggestions on these top configurations and how to make them easily compatible please let me know!
I also have an older style nutmeg Kayline half soft top that uses the snaps to attach to the body which I will be placing on another one of my Scramblers. Does anyone have installation instructions for this style of top? I am mainly needing to know where to place the snaps and if the Kayline hardware is similar to the Whitco hardware. I have only found the installation instructions for the half soft top that uses the belt rail system.
Thanks in advance!!! I want to get any potential problems/issues cleared up in advance so when I get back to Kansas in a few weeks I can get to work on my Jeeps again!
