Steering Column Orientation
RockTractor
Albuquerque
NM
I'm installing a rebuilt steering column and Flaming River DD shaft in my Scrambler project and was wondering if there was a "center position" for the steering column itself. I have the PS gear box centered and the DD shaft cut to fit - but, it seems like I could install the steering wheel in multiple positions. I'm guessing there is a correct position so that the blinker cancel cam works properly. I'm also guessing, based on my research so far, that the horn button should be at the 10:30 position when centered. But, I can't seem to find anything definite that says this...
Can anybody help me out with this so that I only have to install this thing once? :-)
Thanks, in advance.
On OEM columns there is a little notch cut into the top of the shaft right where the steering wheel nut screws on. That points straight up. But I don’t know if FR does that. I would think that you would want to center the wheel between the cancel cam nubs. Although, the intermediate shaft is keyed and only goes in one way, so that might determine everything else. Get the gearbox centered and go up from there.
Thanks Randy!
I'll give it a look tonight and see if that makes sense.
Well, I didn't see any notch "cut" in my column. I did see a notch that looked like it was hammered in with a chisel (not very factory-looking)... perhaps this is it. I also noticed that this mark aligned with the large spline that only allows the lock plate to be installed one way. It's probably a pretty good bet that this is it.
The column came without the ignition installed - so, I'll have to dig into it anyway. I'll verify everything then.
Yep. Notch looks like it was cut with a chisel.
