Steering wheel play
GarScramb
Parkersburg
WV
No-power steering issue. My steering wheel seems to have too much play in it. Can anyone please suggest what I need to check/tighten to get this corrected? I can turn the wheel at least 1/8 turn with no reaction.
Thanks in advance.
Gary
I had the same problem. I tired serverl things to correct it and it's much better so take from my experience what might work for you.
I was suggested to install/replace the steering column bearing kit (you can find them on E-bay or other 4x4 catalog. The other suggestion was to replace the steering shaft (since the lift it was stretched a little bit) It's kind of square and it twists within itself (hard to explain it) like two square rods (one within the other) however the inner flexes within the outer. I would replace it with an aftermarket one like Flamming River (can be found in some 4x4 catalogs) and it helped a lot.
I had the same problem, replaced my steering shaft with a Borgeson unit.
Check the play in the lower coupling on the shaft - where it attaches to the steering box. Lay under the Jeep, grab the lower end of the shaft, and see if there's play (up and down or twisting). If so, replace the steering shaft. Very common wear point for CJ's.
Borgeson shaft fixed it up great.
BTW, I had to sawzall the old shaft to get it out, not enough play in mine for some reason to slide either coupling off.
I agree with the potential issue with the steering shaft. Go with a Borg Warner or Flaming River cromoly shaft and you should see some improvement. Other areas that you should address are:
- Tie Rod ends- if they are worn- replace them(check for cracks)
- Steering Gear Box- Make sure the bolts that hold the gear box in place are tight and watch it while someone else turns the wheel back and forth- if it moves thats what it does when you are rolling.
- Tighten up the adjustment on the steering gear box- you can probably firm it up some.
- Shackles- Often overlooked in steering problems but excess shackle height or poorly made shackles will have an adverse effect of steering- see if they move around alot when the steering wheel is turned.
I am sure these are not all problems on yours, however a combination of any of them can cause steering problems.
Thanks
Kyle
I had the same issue on my CJ7. Once the I adjusted the steering box it was solved. I would start there.
In the front of the jeep, look down through the hole in the front crossmember, you will see the adjustment nut. Loosen the set nut and with an allen wrench slightly tighten the screw. Do not get your steering too tighht as it will cause excessive wear. Test the steering, then titghen some and so forth till it feels right. The holding the adjustment bolt on place tighten the set nut. I would do this first then go from there.
