- Thayer
- KS
Having issues with dad's old daily driver. 1981 with a 4.0L AX15 swap we did back in 2011. OBD1
Jeep started acting up (bucking, sputtering, dying) before dad's passing and has just sit the last couple years.
I've been trying to get it back on the road.
It intermittently loses the injector pulse. So first thought, CPS, changed that out with a know working Mopar sensor. No change.
What really baffles me is when the injector pulse goes away, I can dump a bit of gas in the throttle body and it then starts every time. Sometimes runs great for awhile until it's shut off or dies, then you have to wait awhile (for injector pulse to return) to restart without gas to the throttle body.
Fuel pressure is always good.
Always have spark when injector pulse disappears.
I am getting the 5V ref from computer.
Other components swapped with know working parts:
(3) different computers, map sensor, coil, CPS
Swapped auto shut down relay out.
My OBD1 scanner took a dump, so no help from that.
The original computer harness plug was broke, I thought maybe it was not keeping good connection to the computer so I pinned it out and replaced.
4.0 fuel pressure regulator & flywheel
I have installed a 1995 Grand Cherokee 4.0 eng in my 81 Scrambler. This eng does not have a fuel pressure regulator on the fuel rail and does not have a return line to tank. I want to mount an inline fuel pump, regulator, and filter (or filer/regulator combo) at the tank area. I believe I will...
www.cj-8.com
