Stupid tranny dipstick leak, help!
Alaskan Postal nutjob
FORUM MANAGER
There's not enough posting on this board, so I didn't bother searching, if anyone is too horribly annoyed I apologize :D
I have the TF999 auto 3 speed and my dipstick tube is leaking at the base where it fits into the tranny housing. :(
I had the tube out a couple weeks ago when I dropped the tranny and I was very careful when pulling it and reinserting it. I cleaned the O-ring off with a clean rag and lubed it with clean tranny fluid before reinserting it to avoid tearing it. I bolted the brace back onto the correct tranny-engine bolt and it seems to be in there darn tight.
Anyone had this problem and is there some easy solution? I was thinking of just using some hi-temp sealant of some kind around the joint, but I don't want anything permenant (no JB Weld) that will cause headaches later.
I was hoping someone would have a specific product to suggest before I go stare at all the choices at the auto parts store tomorrow.
I need to get this resolved for this coming weekend, I am dying to head up to the Fall Scramble, even if I have to pull over every other mile and add fluid to the thing. Please help me avoid having to do that :D
Yeah, I've had that problem before. Here's the answer, always use a new o ring and lube it with some vaseline. The vaseline won't cause any problems and it provides superior lubrication for reassembly without damaging the o ring.
O rings are dirt cheap - buy at least 2, either as a backup if the first one gets damaged upon reassembly or to have a spare readily available for the next time you have to disassemble it. Use a razor to cut off the old one, head to your local hardware store and match them up.
It's frustrating though that Î checked that O-ring because of the potential for this exact problem and it looked to be in perfect condition. Argh.
I'm headed out now and will get a new o-ring, probably just grab a numebr of different sizes to have around.
I'm also going to seal up around the pipe with RTV after reinstallation this time (as per another reply on JU) to be doubly sure.
Thanks.
