Super Swamper LTB's
Didn't know where to post this, didn't see a tire section:shrug:
Thinking of putting some 34x10.50x15 Super Swamper LTB's on my project Scrambler. They are the only company that makes a tire in the size i want, besides Simex, which you can't get in this country:(
I know one big concern people have with these tires is the fact that they are bias-ply. That doesn't bother me, I ran a set of bias TSL's for close to 35,000 miles on a daily driver and they didn't bother me. They do tend to "flat spot"after sitting for a period of time, but after a mile or two they are round again. The fact that they wear quicker then a radial does not concern me greatly since this wont be a DD.
If I go back with the bias ply Swampers, I knowingly accept the fact that:
1) they are loud
2) they are harder to balance then a more street friendly tire
3) they wear out faster then radials
4) poor wet/icy road traction without siping or studs
The advantages:
1) stronger sidewalls then a radial (bonus for me since I blew the sidewall out of a radial TSL after extended driving while aired down)
2) the 10.50 width means they should mount fine on my factory 8" rims, and they should "tuck" well under the fenders and hopefully not rub
3) the 10.50 width is lighter then the 12.50 width
4) no radial dual purpose offroad tire is anywhere close to having the capabilities of a bias ply Super Swamper offroad (BFG's, MTR's, Cooper, Bridgestone, Firestone, etc etc)
Any thoughts or opinions?
I would like to hear back from someone running these tires, especially the size i listed. Hopefully they are close to the 34" height when mounted on an 8" rim. The 33x12.50 bias ply TSL's I had before, when mounted on an 8" rim, actually measured a true 33" tall, unlike the radial TSL's (33x12.50) I had mounted on 10" rims, they only measured 31.5" tall.
CJATE used to run these on his CJ5, he isnt on here much any more but I'll poke him and see if he can give you his perspective. From what I can recall I think you hit most of the points and understand them well. I wouldnt personally run 10" rims with a 12.5 though, shortens it up and makes the bead unstable at low pressures, 8 or 8.5 is my choice fwiw, 7" even with the 10.5s
Appreciate it:thumbsup: One guy on our local jeep site that used to run them said they were not the best on rocks, but another guy says that he absolutely loves them on rocks:crazy: I am obviously not building a "rock buggy", but I do take my jeeps on some rocky trails. Both said they were great in mud, which is usually a given for a Super Swamper. And of course, with a Super Swamper, not the best in the sand, especially given the 10.50 width.
Still not 100% on these tires, I might end up with some 35x12.50 BFG KM2's or maybe even the Dick Cepek Mud Country's. The BFG's seem to do well for a more street friendly tire, the Dick Cepek's have a lot of good reviews, but I have never seen one perform in real life:shrug:
Back to the LTB's:thumbsup:
Little concerned that the 34" LTB's might not be tall enough:shrug:
What really drew me to the 34x10.50 size was that it would fit under the jeep good, and look "stock". But, with CJ width axles, a 12.50 will "tuck" and not look too bad. I have always ran 33x12.50's before, but need to step up to a taller size due to the wheelbase and rear overhang handicaps of the CJ-8. Might just end up with a 35x12.50x15 LTB.
Just really trying to nail down tire overall height issues. The 33" Radial TSL swampers I had before only measured 31.5" once on the jeep. Figure a 34" will be closer to a 32.5" height on the jeep. The 35" LTB's say they have a 35.2" overall height, if that comes out to an actual 33.5" - 34" mounted height I will go with that. But, some Swamper sizes run truer to the actual advertised height, and some run taller; i.e the 36" Iroks are closer to a true 36"-37".
Anyone know what the actual height of a 35" LTB is :shrug: Need to keep my rolling radius close to 17" (34/2) for my gearing:thumbsup:
I have not run the LTB's, but I will comment on the 10.50 width....I like it on Jeeps vs. the 12.50 width. Tire contact pressure makes for better handling on most surfaces, and not too much for conditions requiring a little floatation when aired down. The 12.50's in my opinion seem to float and slip around too much.
Regarding, the height/rolling radius, Interco's web site lists the dims as 33.6" tall w/603 revs/mile on 8.5" rim. http://www.intercotire.com/tires.php?id=7&g=1
Look for the Q-78 version. It is actually a little taller than 34 and has the 10.50 width. You can get it in 15 and 16" diameter for the wheels.
Carl
I have ran 10.50's before, but for the local conditions the 12.50's flotation advantage is a desirable trait. Lots of loose sand/mud around here. But, I wouldn't mind trying out a 10.50 again:cheers:
The 33.6 is the unmounted height. From all the searching I have been doing, most of the people who run the 34" version say that it is between 32.5" - 33" once its mounted on a rim and put under a Jeep. Little too short for me. I do know that the 33x12.50x15 bias ply TSL's actually measure a true 33' tall when mounted on an 8" rim under a jeep. I had those tires before, but the LTB's softer compound seems like it would be advantageous:cheers:
I really need/want a tire that will measure close to 34"-34.5" tall once it is mounted on a rim and placed under the Scrambler:fingerscrossed:
Carl
The Q-78 versions look good, but they are probably a little too tall for my gearing and motor:( I need a "short" 35" tire that is taller then a tall 33" tire, really need/want a true 34' tall tire:fingerscrossed:
I emailed Interco to see if they had any more info on the 35x12.50x15 LTB (LTB-206). Site says it has a height of 35.2, but that is the unmounted height. If that particular tire mounted on an 8"rim is actually between 34"-34.5" tall, that is probably what I will get:fingerscrossed::fingerscrossed::fingerscrossed:
No new 35" LTB's for me:( At least a 6 month wait due to the Denham plant closing. I think that plant closing is going to affect a bunch of tires 35" and bigger, and not just Interco. If you want 35's or bigger, better snag them now or you will be waiting a couple of months. Takes about 6 months to move production to China..............
Choice now is between a regular radial 35x12.50x15 (BFG KM2 or Dick Cepek Mud Country) or the 34x10.50x15 LTB.
I need a denman ground hawg for a spare and i hope they open back up soon. It is hard to get tires up here, it is a good month wait on most any tire and only going to get worse,
have you looked at the truxus? a buddy runs a 34" on a 16" rim, not sure of the actual mounted height but maybe closer?
This is NOT good news to hear. I would avoid the first run of tires from China untill they get the bugs worked out.
Too bad availability is gone, the people running the LTBs up here either love them or hate them, with more people loving them.....and I suspect your trail conditions are very simular to ours up here.
I'm running first gen 35" Goodyear MTr's. they are not bad, but you can get them anylonger.
BigWalton seems to love the new Wranglers he bought, you may want to ask him how tall they are.
I looked at the Truxus, but heard they had "weak" sidewalls. After blowing out the sidewall on a radial TSL while offroad, I am leaning more toward a bias ply tire again. The Truxus line does have some good sizes, though:thumbsup:
I am probably going to end up just getting a set of (x5) 35x12.50x15 BFG KM2's for now. Once Interco starts making the 35" LTB's again I will probably get a set of those for offroad use only, mount them on my factory 7' rims:thumbsup:
I went through two sets of the first gen MTR's on my TJ Rubicon daily driver/sometimes weekend toy. They did good on all terrains, not the best on mud, but after running Swampers, its not a fair comparison for the MTR's:rotfl:
I have some of the new Goodyear Duratracs on the TJ now, and surprisingly, for being slightly less aggressive then the MTR's, they have about the same mud performance. They drive way better on the street, too:thumbsup:
I run them. Picked up a used set a couple years ago for $250.00. They are a little noisy but not horrible. They do get a flat spot on them if they sit for to long that rides out in a couple miles. We have aired them down to 8lbs and run them in the sand before with no complaints (other than the motor was under powered). I like the look of the 10.5s on a stock steelie.
I forgot to look back on the thread I started:thumbsup:
The LTB's look great on that Scrambler. What size are they/how much lift/do they rub???:wave:
Forgot about this post as well.
The lift and suspension were on it when we got it. I would guess it is a 4" spring lift with slightly longer shackles. The tires are half tread 34x10.5x15 LTB's. Its more of a putts around town thing than anything else so I haven't flexed it or anything much off road. No rub though as I have noted.
Thanks,
Kevin
