Swapped MC2100 to 258 problems.
New problem. It will barely idle when cold, and will sometimes die, but idles fine if not a little high when it warms up. The choke is working correctly.
sounds like the fuel and air mixture screws on the front of the carb. bottom of the carb one on each side. tighten them in one at a time till just before the motor dies. then back it off a hair. adjust he other one the same way. just wash, rinse, repeat till you get them dialed in.
here's how i did my cable. bad shots, old pics for something else. but should get the point across.
Yup. It was the air/fuel screws. It runs a lot better now. The choke works like it should, but in still working on the idle. When it's cold it won't idle on its own for a minute or two. Once it warms up a little it'll idle better. Once it's at operating temperature it idles higher than I'd like. I may lower the idle with the idle screw and just deal with it when it's cold.
