- Rome
- GA
From the ignition module to the HEI is not to bad.
If you still have the factory Jeep wires, the orange and purple go from the HEI pickup back to the ignition module. (the 2 exposed pins) Then the plug with 2 pin outs feed back to the HEI one to the hot side and the other to the ground iirc. I had kept my jeep factory plugs going from the ignition module to the HEI
If you need some help give me a shout.
The biggest thing to watch for is that when you lock down the HEI that you get it "phased" right. I was a few degrees off and had issues with burning out coils and ignition modules.
sorry to hear about the Grand Eric...
