JEEPTHRILLS
OK so I definatly didnt roll craps on the 250 dollar XJ.
I had done a preliminary cold compression check ( radiator was bad) before i bought it. #2 was 90...everyone else was 155ish...and with oil it only came up 15 psi. HMMM? Carbon?
Today I shoved a hose into it and let it run till the thermostat opened (oil psi above 50)...then let it run some more. After 15 mins or so I gave it a seafoam treatment. ( anyone who has used seafoam..bear in mind I am doing this at the airport...and of course the wind is lightly blowing towards the runway)...I let it sit engine off for 10 minutes or so...reconnected the vac line and started it up and wedged the throttle open to about 2k ( oil psi 60 or better for the whole time). After a minute or so...the real smoke screen kicked in....wow...and i thought marvel mystery gave a good smoke show!
So after 5-10 mins the smoke cleared...and of course just before the smoke cleared one of the airport guys comes driving over thinking there was a plane that augered into the side of the mesa. I kissed a little butt...and apologuised for the disturbance.
Back to the compression test:
1. 154
2. 155
3. 156
4. 152
5. 157
6. 155
Score!
Was gonna throw the plugs back in..but then I looked at them...gap seemed a little excessive. I measured them up at about .085....just a little off from the .035 spec. But still ran like a champ...and the P/O was stating 21mpg prior to the "incident"
I was almost hoping for the number to not be so good...mainly because 4.0L swap is good...4.7L swap is awesome....oh well...it will have to wait for now.
1. 154
2. 155
3. 156
4. 152
5. 157
6. 155
Score!
