Not entirely apples to apples comparison here; but, maybe this will help.
I had an '84 CJ-7, AMC 150, T-4, 3.54 axle ratio, 31" tires. Typical MPG was around 19-20. It was marginal on power. If you had a strong headwind, your top speed would become limited around 65mph or so. If you had a long uphill grade, your speed would become limited to around 60mph or so. And, if you had both at the same time, your top speed would be around 50-55mph. All that said, I had pulled a trailer filled (approx 2,000 pounds) and ran with traffic (55mph) with no problems...but it was a flat ground area.
I have an '83 CJ-8, AMC 258, T-5, 3.31 axle ratio, 31" tires. Typical MPG (stock) was around 18-19. After changing to a Weber carburetor, the MPG decreased a touch to 17-19 (though I have not fully dialed the carb in and I am sure it would improve if I tried). There is absolutely NO issue with power. And, the added 5th gear overdrive made life much happier.
I have an '88 Grand Wagoneer, AMC 360, NV727, 2.73 axle ratio, 30" tires. Typical MPG (stock) is around 13...no matter how I drive or what I pull with it.
