The 4cyl and 4speed
Flatie46
Russllville
TN
My 81 CJ8 has the 4cyl engine, it dosen't run. It's been sitting for years has parts missing. I am pretty sure I'll put a 304 in it. I'm cureious though, what kind of mpg's do you get with the 4cyl? Also, I've been told by the prev owner the trans was weak, are they? I mean would it handle a mild Chevy 305 driven (somewhat) sensably?
Not sure on the mpg, but I'm sure it's not more then 15mpg. Is the trans you have the T4? I guess it could survive, my friend had a t4 behind his 360 for a while. If your swapping to the 304, bolt in a T176 trans. If your doing the chevy, put in a SM 465
The Trans looks like the sr4(which will be splined for the 4cyl)
See the spring at the base of the shifter !
I also suggest the t176 !!!
The transmissions used behind the 151 Iron Dukes used the same 10 spline input shafts as the 6 and 8 cylinder transmissions. When AMC began using the 150 I4 is when the transmission input shafts changed to 14 spline. Though the spline count will be correct, the SR4 is possibly one of the weakest transmissions ever put in a Jeep! Like Jim, put me up as another one to suggest a T176 to replace it!
Not entirely apples to apples comparison here; but, maybe this will help.
I had an '84 CJ-7, AMC 150, T-4, 3.54 axle ratio, 31" tires. Typical MPG was around 19-20. It was marginal on power. If you had a strong headwind, your top speed would become limited around 65mph or so. If you had a long uphill grade, your speed would become limited to around 60mph or so. And, if you had both at the same time, your top speed would be around 50-55mph. All that said, I had pulled a trailer filled (approx 2,000 pounds) and ran with traffic (55mph) with no problems...but it was a flat ground area.
I have an '83 CJ-8, AMC 258, T-5, 3.31 axle ratio, 31" tires. Typical MPG (stock) was around 18-19. After changing to a Weber carburetor, the MPG decreased a touch to 17-19 (though I have not fully dialed the carb in and I am sure it would improve if I tried). There is absolutely NO issue with power. And, the added 5th gear overdrive made life much happier.
I have an '88 Grand Wagoneer, AMC 360, NV727, 2.73 axle ratio, 30" tires. Typical MPG (stock) is around 13...no matter how I drive or what I pull with it.
My Jeep has had 3 different engines. The stock 6, then 15 years with a 350 4 bolt, and the last 10 years with a TBI 305. It has only had 1 transmission, the T-176. I've got no complaints.
