DustyRhodes
- Rosenberg
- TX
After over 1900 miles, a blown out rental trailer tire, and 72 hours I've got my '83 Scrambler back to the house. Structure wise it is in a lot better shape than I thought it would be even though the place I bought it from sent me a bunch of pictures I was waiting for the worst, mainly the areas they decided not to photograph but other than some pinhole to nickel size rust holes here and there in the driver and passenger floorboard and one obvious Bondo spot on the passenger rear quarter panel a couple dents on the hood and one front fender the rest of the Scrambler looks good. Mechanically I'm not too sure. I did take it on a test drive and had a few questions which they said where "just how these old jeeps are" but honestly after the drive there and havin cash money in hand and being in my price range, and etc. it I couldn't turn it down. So now I have a few questions for yall here on the forum. Please forgive my "inexperience" but I haven't ever owned any kind of Jeep and this is my first non-diesel vehicle in several years, so the spark plugs are throwing me off....
So here are my questions and help will be greatly appreciated.
Steering-It is super loose, so loose in fact I am nervous at this point to drive it very far, I am attributing it right now to the bald and dry-rot tires but I am going to put a newer set on tomorrow, that the dealer gave me, they are not much better as far as the bald part but they are not dry-rotted. So Ill see if that helps, my question is there a way to adjust the steering gear box, or should I just replace it? Or is there something else in the steering mechanism I should look at specifically? Also it has what I think is a 2" body lift and 33x12.50/15 tires.
Fuel System-I have a leak on a fuel line which I am also going to replace tomorrow, my question on this is what is the fuel system component that is mounted up in the rear driver side corner of the Scrambler? Fuel Sending Unit? Fuel Pump?
Transmission-going up it shifts fine no problems at all, going down it will not go into 2nd gear. Any suggestions or ideas? Maybe the clutch?
Thank you in advance for any help suggestions.
Here's some Pics too.
On the way back
Off the trailer at the house
Once I got the Doors and Hard Top Off
On the way back
