The New, to me, Scambler
DustyRhodes
Rosenberg
TX
After over 1900 miles, a blown out rental trailer tire, and 72 hours I've got my '83 Scrambler back to the house. Structure wise it is in a lot better shape than I thought it would be even though the place I bought it from sent me a bunch of pictures I was waiting for the worst, mainly the areas they decided not to photograph but other than some pinhole to nickel size rust holes here and there in the driver and passenger floorboard and one obvious Bondo spot on the passenger rear quarter panel a couple dents on the hood and one front fender the rest of the Scrambler looks good. Mechanically I'm not too sure. I did take it on a test drive and had a few questions which they said where "just how these old jeeps are" but honestly after the drive there and havin cash money in hand and being in my price range, and etc. it I couldn't turn it down. So now I have a few questions for yall here on the forum. Please forgive my "inexperience" but I haven't ever owned any kind of Jeep and this is my first non-diesel vehicle in several years, so the spark plugs are throwing me off....:crazy:
So here are my questions and help will be greatly appreciated.
Steering-It is super loose, so loose in fact I am nervous at this point to drive it very far, I am attributing it right now to the bald and dry-rot tires but I am going to put a newer set on tomorrow, that the dealer gave me, they are not much better as far as the bald part but they are not dry-rotted. So Ill see if that helps, my question is there a way to adjust the steering gear box, or should I just replace it? Or is there something else in the steering mechanism I should look at specifically? Also it has what I think is a 2" body lift and 33x12.50/15 tires.
Fuel System-I have a leak on a fuel line which I am also going to replace tomorrow, my question on this is what is the fuel system component that is mounted up in the rear driver side corner of the Scrambler? Fuel Sending Unit? Fuel Pump?
Transmission-going up it shifts fine no problems at all, going down it will not go into 2nd gear. Any suggestions or ideas? Maybe the clutch?
Thank you in advance for any help suggestions.
Here's some Pics too.
On the way back
Off the trailer at the house
Once I got the Doors and Hard Top Off
Dusty - great to finally see some pictures! Looks nice :)
I'll help where I can:
1) Steering. From my limited experience, the steering box is one of the last things that cause a problem with steering, and one of the last things you should try to adjust. There are a dozen things before and after the steering box that more commonly cause loose steering.
a) steering shaft U-joint play - check to see when you're parked how much you can rotate the steering shaft. Any sort of play is beyond factory specs and it may be worth considering a replacement shaft.
b) tie rod ends and links from the box - go underneath and see how much they move when she's in park. Also check to make sure your drag link is nearly parallel to your tie rod, and both to your front axle. Any big differences in parallel and you could have steering issues.
c) ball joints, wheel bearings, etc - lift up the front end and try to wiggle the wheels. They should be firm, no top/bottom or side/side movement.
d) caster angle - you're lifted, but not too much. You should still have your caster (and the rest of your alignment) checked by a professional.
e) steering box - with the wheels on the ground and you underneath looking, rotate the steering shaft and watch for immediate and equal movement of the pitman arm. If there's not an immediate and equal movement, it can signal fatigue in the brace for your steering box.
So many of these things can fail, and very rarely is it the box...except for when you have cracked braces, and even then it's not the box - it's the braces.
Fuel: Those are your check valves, liquid check and roll over check valves. They're kinda necessary but a lot of bubbas cut them off and then wonder why a) their garage reeks of gasoline or b) why their fuel delivery system doesn't perform well or c) why their CJ blew up when it rolled over.
Transmission: I'm not much help there, maybe you're right? Doesn't it take more clutch to downshift than upshift? :dunno:
Thanks for the helpful links. I have narrowed down some of the steering issues the newer non-dry rot tires helped a lot but there are still some issues, i am planning on doing new front and rear shackles as the ones on it are cockeyed and a HD steering gear box bracket. Anyone have any suggestions on what brand of grease-able shackles to go with? I'd like to get as close to stock height on them as possible too, also I am more than likely going to pull the body lift off and replace with a new either stock height bushings or possibly 1" body lift. As far as my tranny I am almost positive my clutch is going out i plan on getting a new one eventually too and doing a twin stick conversion to the t-case when I do that. Other than that stuff im just trying to go through it again and again so I can get it inspected working on the windshield wipers right now have a issue with the linkage on the passenger side, which someone, PO tried to rig but im going to fix it right cause their quick fix doesn't work.
Buy 2 OEM reproduction manuals, read them from to back, about 1250 pages,
then tear into it once you have a clue how it all is suppose to work.
It will save you tons of time & $$$!!!!!!
Good luck with the Scrambler!!!!!!!
Thanks for the advice on the manuals I already have a Jeep Chilton book, the Jeep CJ rebuilders manual, which is really not that helpful the pictures in it are all black and white and way to small to really be able to see much detail. And I bought a NOS/or reproduction I'm not 100% on that, scrambler owners manual. Any other suggestions on those.
I got one specific to 1982!! It is 2 volumes & very specific to that year, not like the generic Hayes & Chiltons that try to cover 50-60 years & all models!!
It was definitely worth the cost!! I took my $30 Haynes back to Autozone & paid like $60-65 for the repros
Ok now I've got another issue. I had to replace my windshield wiper motor and linkage in order to get my jeep inspected. I went ahead and replaced the original switch too.
Now that I have the new linkage motor & switch installed the motor will not turn off. I've tried both the new switch & the old one same situation with both the motor works fine it just won't turn off. Any thoughts?
