- Branch
- La
I have said it before and read it on here many times that no other forum is as helpful as the people on here. For the last month, I have been working on my father-in-law's 91 Suzuki Carry mini truck that he uses for hunting. After sitting up since last season, it would not run due gummed up complete fuel system. I cleaned the fuel tank, put a kit in carb and replaced fuel pump, filter and lines. Also did a tune up. Well, I could get it to idle correctly so I found another forum and started asking for carb adjustment proceedures and vacuum line diagrams since info on these are hard to come by. After two weeks, this is a response I got from a guy in Ontario:
"As I've posted elseware, if you will go through the trouble of posting up some referance pics of the carb with #'s for all the set screews. I will go through the trouble of describing the carb tuning procedure. Which will not help you if you have not eliminated all of the vac leaks and set the timing properly.
The problem will not be rectified by typing a post. "
It took everything I had not to respond to this guy. In my original post, I mentioned model of truck and model of carb, and a detail of all repairs I did which included checking for vacuum leaks with propane from intake all the way to controls in dash. My son was with me when I read his response and I yelled out a few names and let him read the whole post. His respones was, "Aren't the guys on the Scrambler site a lot more helpfull and friendly? Maybe one of them might be able to help you!" Sorry for the long rant but I just had to say it again that this site and community rocks. By the way, if anyone know anthing about tunning these little truck please speak up.
