Rock Equipment makes the reamer & insert kit...you can get it from OK4WD. Note that once I settle in a bit from my relocation and can lay my hands on it, I can lend you the reamer. I helped a buddy with the Goferit kit...he brought his knuckles over along with a drill bit (you need a big one, I forget the size now) and I chucked them in my drill press then he had another buddy weld the inserts in. The Goferit is probably more durable, but it's also a one way street, the Rock Equipment can be returned to 'normal' by moving the sleeves.
