Tire Gauges
John N
Rockville
Does anyone know of a reasonable way to check the calibration on tire gauges? I have several and they all read different significantly, I have no idea which, if any, of them is close to accurate. I don't use the "pencil" type ones, only the the round ones with stems. I have a Currie deflater, it always seems way low, a Victor one and a Slime one. If I check my tire at what seems like a good inflation for the street, it's at 25 or 28. The Currie says about 22. I could buy another one, but wouldn't know if it's right either.
Another "everything's made in China" product. I bought a half dozen tire gauges and NONE of them were accurate. Every one of them gave a different reading.
I've had the same problem... what's worse is some of them even seem to display an inconsistent aberration (reads lower than accurate at a certain pressure range and higher than accurate at another pressure range). I'm fortunate to have access to some professionally calibrated equipment for comparison.
Surprisingly, in my experience, I've had the best luck with some of the cheap pencil style gauges (usually within +/- 2 psi at typical Jeep tire pressure).
I think it is like bathroom weight scales. They all seem to be off a bit but if you use the same one consistently then at least your the same at all four corners. I don't have any idea if they can actually be calibrated or how to do it. Never really looked into it. I wonder what NASCAR/race teams use? They have to be much more precise.
