Tire Pressure
twmattox
Arcadia
IN
What tire pressure should I be running? 1983 Scrambler with 31X10.50X15 BFG TA/KOs?
on/off road?
On road, probably around 30-35 psi.
On road I run what was listed above.
However, at Hot Springs this summer I went down to 20 and they were still to stiff.
Probably could have done 10-15
I'd run those at 32psi each on he road and off you can run 15psi. I've always run 32 with that size simply because its not to soft and you still get good road/tread contact. That is what I put Alan Clarke at out here last year (off road) with the exact tire. He was surprised at how much better it did on the trail.
You can go down to 10 offroad and not worry about debeading. I run 6-8 and have never popped one. You'll be amazed how much more traction you get at 10 than 15.
I run the same tires at about 26 to 28. Its a personal thing, I belive I get less bounce out of them.
VM
I only have a bead issue if I go below 1psi and in deep snow ruts.
Otherwaise, they stay at 4-5 psi
Sorry, I should have been more clear. I am looking on-road. I had a CJ-7 and ran around 25. However, the glove box door on the Scrambler indicates to run them around 20 (I know that this is for stock tires and mine are different). I just wanted some opinions.
Currently, I am at 25psi. What is the advantage (or drawbacks) to more pressure? How much is too much?
Your only concern with running higher pressures, is abnormal wear on the center of the tread.
get some childern playground chalk and draw a two inch line across the circumferance of your tread. drive a little ways. Look for where the chalk wore off add and subtract tire pressure untill the chalk weres off evenlly across. I think BFG does not like us running road pressure less than 20.lbs
