Tired of AMC V8 HEI Questions?
ScramFam
Registered User
Nowhere
OH
Sorry, please ignore this one then.
I was searching the archives for HEI advice for my new engine. I'm well aware of the "gear matching issue" and have been keeping that in mind as I make decisions. Anyhow, someone on an old thread said that the problem could be solved by simply removing the gear (if it was still good) from the old distributor and swapping it with the gear on the new HEI. No one posted a "You're full of crap" message afterwards. Does that mean that he's correct. And, if that's the case, is there a valid reason to invest $200 to $300 or more on a HEI, when they are plentiful between $80 and $170.
Thanks for your advice.
Matt.
Matt.
That's what the boys over on IFSJA recommend.
well theres other down sides to the cheaper HEI's youll find like on e bay,just rember you get what you pay for,ive been thru 2 cheepos and finally got a DUI and have never been happier.and just think if i had bought the DUI in the first place i would be way ahead on money.
My HEI bought on ebay lasted about 18 months before it chewed up the gear on the cam shaft. Although the gear on the HEI looked fine I replaced both to get a matching set.
I did just that....swapped the existing gear on the old dist to my new HEI. I purchased my HEI thru Bulltear, and have not had it long enough to know how durable it is yet, but Matt at Bulltear claims it's the way to go and better than the EBAY knock-offs. Seems like it was around @190 w/o the dist gear. He also sells matched sets of gears.
I have also heard great things about the DUI as D2Ride posted.
I've been running the DUI for years in my 360, it's been good.
there is something weird about that gear meshup on the amc v8s..in the 80s, i put a new camshaft in my 304 and from that point on i could not keep dizzy gears ...never did figure it out...the solution i finally used was to to replace the 304 with a 396 Cid BBC...not sure if that is an option with you.
hei gear
mine is a 258 the gear is bigger than the shaft.i think thats what busted mine a few days ago.i'm trying to find out if theres another gear to get.just my though
