TJScrambler - Getting Started
And u said this was a good body to start with .. gezzzz
Sent from my SM-N910P
CB wrote...Last night my dream/nightmare started with zr having Leno money and buying like 50 cjs. Mostly scramblers however he wanted all to be restored and hired me to be the helper. Nooooooooooooo
You are fired.............
I am showing everyone that even though it looks good on the top/outside, underneath, there is always rust.
The rear was shot and the front floors I knew... replacing the whole floor at this point is just for piece of mind to know all the metal is clean/fresh/rust free.
Also, any idea where I can get the seat belt lower mounting b pillar bracket?
The lower part of the driver side was rusted pretty good... I looked around and all I see is a YJ replacement one, which could work, but would rather something closer to what is there.
It is the driver side, and I need like the lower 2 inches of it, the rest of it is pretty solid.
Looks to me like the only good metal left is the cross braces you welded in to hold it together. I tried but I just couldn't hold it in any longer. :)
More cutting
I couldn't imagine putting that together without complete sides (to be able to judge proper placement of floor to sides). I'd have to do it in sections, replacing the sides first. Excellent work.:bow:
Something you just might be interested in. I found a coating made by 3M called Weld-Thru II. It's a weldable, corrosion resistant coating, part # 05917 that you could prime some of those parts with and still be able to spot weld or weld through. I used it and found it worked very well for those places that you would not otherwise be able to prime and paint. It even had a Nascar logo on it.
Well, the sides are going to kind of end up going where they go.
I got the rocker replacement panets and measured 15x before I cut, so they should slip in to the correct height.
As for where it lies on the floor, there isn't much I can do about that.
The floor is one piece and very rigid.
It fell into place pretty easily, so that tells me I am close to square in relation to the panel.
I have a bit more tweaking and cleaning up the connection points, but for the most part it sits in place.
At this point, I am glad for all the bracing that was done.
I am glad that it hasn't folded up.
I know the floor fits the frame, as I tried that, so really now it is just getting it all tacked together and putting it back on the frame and make sure it all lines up.
That is a lot easier said than done... probably need another 100 hours or so and a lot of taking off the floor and back in for tweaking and final adjustments.
Hmmm, I thought I put those pictures up, but I guess not.
I used a different brand, but it was a weldable zinc primer.
I used it on other Jeeps before.
I used it so far on the top of the firewall (upside down at this point), knowing that won't come apart again and will be spot welded (once I get a spot welder).
