TJScrambler - Getting Started
42 drilled holes and 42 screws 3 hours of second guessing
Nice work! That's more than I would ever be willing to do.... :bow:
I see a lot of sheet metal screws that presumably are just place holders until you get things welded. I was going to recommend Clecos, which are used extensively for aircraft sheet metal... but I see you have a few Clecos in there as well. Do the screws hold tighter than Clecos?
I was thinking the same thing. I wanted to ask CB if he was an aircraft mechanic. From a distance it looked like riveting in the floor. Only an A & P would do that
Sent from my iPad
I am not an aircraft mechanic, but I am an overly attentive Electrical Engineer perfectionaist, so this process is killing me. I am using 4 different sets of sheet metal from 3 differnt vendors.
Original sheetmetal on the sides/cowl/bracking - Jeep
Front firewall - From 1982 Jeep CJ7 donor
floor/wheel wells, rocker trim - Classic Ent
Front floor section from Omix or someone else.
So, I just have to accept that it isn't going to be "perfect" and accept some of the small imperfections.
I am happy it is finally able to be moved.
Next up is a mounting system to hoist it and put it on the chassis for the winter to get to some other projects that need to get in before the snow flies.
I will get back to this in the spring probably after I build the "off the shelf" build... that will be coming soon.
2 different angles 79 tear down coming along
T18/dana20 soon to be out and for sale
I'm glad to see this tread moving along. You've been a great reference both here and on other helpful threads. You've got me wanting a set of mud flaps really BAD! hint, hint
Long day 2 trips
Still have to go back for tubs noses and hard tops
Been a while on this one... but since I snagged the cage out of it to put in the truck project... I had to replace the cage... Rockhard4x4 sport package arrived today.
I just wish they were closer and not have to ship freight... that costs a lot of time and money.
I built a full cage for mine because I wanted the protection and ability to have shoulder belts in the back for my kids but in hindsight I wish I went and just got this kit instead and weld bungs into it.
