To do or not to do
daltonw
Scrambler Enthusiast
Claflin
KS
wanted some extra opinions on putting dana60/14b under the ol scrambler. i'm on the fence. i bought an 84 gmc srw 1 ton the other day for this project but getting cold feet. my jeep already has a sbc 350/th350/np203 so it's not exactly stock. running dana 30/amc 20 with lockers front and rear with 4.56 gears and 35s as of now. also picked up a set of 37s on hummer wheels for this deal. since i have all the parts and tools to do this swap i probably should follow thru with it. i mainly use it for farm use and a little bit of wheeling but not much. if i do this i could see myself using it more. but once i do this i feel like my scram will never go back to being close to original. i am also thinking about swapping the th400/np205 out of donor truck because my th350 is shot. the th400 seems like a bit of overkill.
any thoughts or opinions are appreciated. anybody regret doing this swap? point me in the right direction i guess
There are a number of folks I know that have gone big and regretted it later.
Why do you think you'd use it more with these axles/tires? Not saying you're not right, but the folks I'm referring to went big and found out that it was less drivable/streetable and they ended up using it less and when they did do things, they were over-capable and things weren't as fun as they were before when they had less rig. Talk through why you think this would be a benefit to you and see where that goes.
Just my :twocents:
You're really the only one that knows what you need out of your truck, but since you asked....
It doesn't sound like you need to go that big. I'm assuming you are talking about full width, so you'll be adding loads of extra weight and completely changing the driving characteristics of the Jeep. If you enjoy it now, you might not like what you end up with.
Personally, it isn't something I would do to my Jeep. I love the way Scramblers look, so while there have been significant functional changes, I've pretty much left the outside alone. Just mild lift and 33s. Nice and light, simple, and loads of fun to drive.
I like to try to keep things "all AMC" so take my opinion with a grain of salt. You're talking about putting a lot of beef under a pretty narrow frame and body. If you don't plan to take up rock crawling or bogging anytime soon, I'd leave it with the stock axles. It sounds plenty capable as it is for what you want and is a heck of a lot lighter to boot. A D44 is the biggest I'd want to hang under a CJ, but that's me. I like street driving mine and when it goes offroad it's mostly fire trails, mild obstacles, etc. If you haven't already done it (but since you have a locker you probably already have), but you could put 1 piece axles in the rear if you're looking for extra strength. If you're looking for a project, you could always clean up/build the axles out of that 1 ton and make some good money, assuming you got the donor for a good price. We all know what crate axles go for, so you shouldn't have a hard time selling a nice set of heavy duty 1 ton axles.
I was assuming you would cut them down in width, do not go full-width IMHO. Just had that conversation with someone today on the phone over lunch...
well you guys talked me out of doing it and rightfully so. to me my jeep has the perfect stance so why change it. it would be a waste of time and money in the end any how. my current set up does just fine as is. i may truss the amc 20 tho. i'm already running 1 piece shafts in the rear. the added weight and width for me would not be beneficial. now i got to figure out what to do with all these darn parts. shoulda thought about it more. only thing i'm going to use off the pick up now is the np205. maybe i will make my money back on it. what's a fair asking price on a dana 60/14b?
for the last year or two i've wanting to make a mudder/crawler out of an old toyota pickup anyway. shoulda just followed thru with it. i guess i can save the 37s for it.
There was a pair that just sold in the classifieds for $1800 I think, though they were already built/set up. Not sure what is in yours. If they're "junkyard fresh", you could only be looking at a couple hundred a piece as they are fairly easy to find in yards. But if they're set up with gears, a locker, etc... much more obviously.
