i didn't like them on the TJ, but i flat out HATE them now. what "engineer" came up with these as a good solution? my new mission in life is to throw every torx bolt i can find as far away from me and my 8 as possible. sorry. i feel better now.
Cooter said:If you think the Torx is bad, you should try removing the ones on earlier CJs- with a flat screwdriver![]()
I think you should be more upset with the PO than the engineers.
I once had a Challenger convertible that was wired by the PO with #12 solid and wire nuts- he had a bad turn signal when he started.gp'n Jake said:trust me, i am much more upset with the PO than the engineers. the engineers had nothing to do with the 4th grade wiring project that i have to debug.
