Tuffy Console Fail [Video] I suggest you check yours...
dyldebus
Encinitas
CA
Well I discovered this by accident today. Lean your weight on the arm rest, push the button and pull up and down... Opens right up when locked. Hopefully mine is a defect. Can anyone else replicate?
[video=youtube_share;TJzsggkxefE]http://youtu.be/TJzsggkxefE[/video]
:angry:
Just tried mine and this does not work. Mine is an older model (about 10-12 years). The older ones had the bearclaw latch on the body not the door. So my setup is different than yours.
I also have a glove box that is newer (2 years). It has the bearclaw on the door. I couldn't get it to do it either.
Does is only open when locked if the lock is pressed in?
I also have the Tuffy glove box and it does not have the problem. Mine definitely has the claw on the lid. I can take a pic later. You have to press the button when locked while putting your weight on the lid and it will pull right open.
Is there any differences between your console and the glove box bearclaw latch? I only ask that because I was looking at my glove box to see how it was happening. Also, if they are you could swap part between them and test it out.
Have you tired to get the latch to open when locked with the lid opened? What I mean is get something (like a socket extension or screwdriver) that is a similar diameter to the pin the latch clamps onto and try to recreate it opening in the locked position when you can see what is happening. That or try to position you camera in the console with a light.
I have the older lock system and it has been attempted to be broken in to.. they used a screwdriver and pried and bent the whole cover up but the way the old lock works more u pry harder to open.. worth every penny just got a hammer and bent back onto shape. Used black spay paint and looks new again..
Sent from my SPH-L900
I have the older lock system and it has been attempted to be broken in to.. they used a screwdriver and pried and bent the whole cover upbut the way the old lock works more u pry harder to open.. worth every penny just got a hammer and bent back onto shape. Used black spay paint and looks new again..
That is what I call NYC tough. To hell with Gorilla tough! ;)
Maybe I should have bought a used one with the older latch. I'll try to debug mine. It's finally at the shop getting re-geared so it won't be until Saturday.
You try calling Tuffy? I've got three of their consoles, and their customer service has been excellent every time I've dealt with them.
I wasn't having any problems until I looked at this video....I hadn't tried to see if mine would do this. The other day I pressed the button to get into the box and the button stayed depressed and the lid will not open at all. Going to give this a shot or.....I don't have my elbow pad on it I may cut a hole in the lid to get it to disengage. Looks like I have the same dimples in the lid near the button.
ok, so.....I am now holding a lock cylinder in my hand.....and it still isn't opened. Hmmm......
That seems odd. Did something in their jam it up when you closed it? If you have the cylinder, you should have have the piece that swivels to actually lock the lid. Right?
Dain
I have a nice threaded hole at the bottom of the cylinder that came out. I started to drill a hole with a hole saw in the top under where the pad goes ( no elbow pad on it right now) man that steel is hard. I wasted two hole saws so far. I plan on cutting the hole, getting it open and fixing it or replacing the lock. I will save the cut out and weld it back in and paint it.
ok so I got back to it today. I ended up using an angle grinder with a cut off wheel to get inside. mine is set up so the button pushes a lever and de activates the latch. With that being said, if this ever happens to anyone else, use an Allen wrench and turn it around in the hole until you can push down. It should open right up. No need to cut a big hole in the top. Now for my next project, weld the hole and build a new pad for the top.
