uh... oops.
jeepdreamer
Colorado Springs
CO
Seems I acquired another project. :O
91,4.0,5 speed,231,rust.
Yikes!! what's the plan?
Well... I don't really know yet. The Scrambler is getting closer but will soon hit the money wall again for drive shafts and some other things. Plus its so expensive to drive around here give the thirsty V8... It may get back burnered and tinkered on slowly until I leave here to come back to the states. I will get it moving under its own power soon and that will be enough I think.
As for the Cherokee... It may have to get fast tracked into service since my lil beater VW Golf is having fits. Thankfully I know Jeeps... VWs... not so much.
The short list from what I've seen on it will be order ft/rear main seals. install those and the provided pan gasket so I can see how it runs. Shortly after that will be a very intense BATH! Its nasty underneath! Oil spillage and peeling undercoating and mud and rust... lots of yuck! Once its clean and maybe some of the undercoating scraped off it will get a close inspection so I can see what I need to repair. The rockers are rusted out and the PO started to cut it away and even got patch panels from another junk XJ. Most likely I will DX that plan as my body work skills suck. haha. I will find some rectangular tubing, cut off whats left of the rockers and make skids. The tubing will be permanently welded to the rocker and pinch seam as well as braced to the uni rails. Its a pretty common mod for XJs and in this case actually easier than fixing whats there.
The other things I see that need addressing are:
The rear bumper. Will likely fab a new one. The existing one is shot and looks to have had a swing out on it at some point that did it no good. Should be pretty easy to make one.
The front bumper is ok but the huge brush guard is very loose. I will either see about making it better or toss it and start over with one of my own ideas. I do have the other winch I was going to use on the back of the CJ8 that could be used here...hmm...
Need to just get it running and driving first to see what is needed. Then I will have to insure it, have it inspected, and get tags for it. I guess the idea is to build a cheap wheeler for use here on a small budget. The end result being something I can DD and play with but sell before I leave and get money for it. Shouldn't be hard to see a profit since I only paid 500 bucks for it. It does run but he pulled the pan to fix the oil leak and then realized it was more work than he had time for. Seals are pretty cheap. I should be able to finish in a day once they get here. Then I can see what I'm really working with.... I'll keep this updated as I go. Been a while since my last XJ and I'm excited.
