Water Pump Question
Bryanf
Clarkesville
GA
I need some help diagnosing a problem. I was driving to the golf course today and started to hear a faint squeak coming from the engine compartment. I had never heard it before as it started all of a sudden. I pulled over, raised the hood and the sound was coming from somewhere around the pulley area where the water pump is located. By the time I got back home the squeak had become more constant and louder. I kept an eye on the temp gauge and it never heated. Does this sound like a failing water pump to any of you engine experts?
Can you wiggle the fan front to back. I just replaced mine because of this figured better safe than sorry. Now I hear a squeak coming from my alternator
Thanks for the response. The fan does have some movement from front to back. Someone else told me that might be bad bearings. I'll probably try to replace the pump just in case. I saw an old post on this site where someone described the fan going through the radiator.
I replaced the water pump myself and got it all back together with no problems. Then filled the radiator, cranked and let it idle for a while to get to operating temp. The sucker ran hot... Turns out the thermostat was stuck and would not open. So, I replaced the thermostat this morning and all is well. I never had any thermostat problems before the water pump issue. What's up with that? The water pump and thermostat were only three years old and have less than 10k miles on the engine rebuild.
Maybe in the process of removing the pump, something came loose (part of gasket, dirt, etc.) and got to the thermostat. At least all's well in the end.
I've heard if thermostats being bad out of the box, so it wouldn't surprise me if it went even though it wasn't that old.
