Funny how things work out! I just logged on, saw your post and looked at the NEWEST new member: "Mike W" Let Me be the first to extend a warm welcome and request some rig info and a picture!
-Mike W. aka WildTurkeycj8
Hello Yall,
I am pretty new also and have a few questions for the more knowleadgeable. The pic is my scrambler bought at auction after searching for a year. Engine recommendation for highway speed and farmland driving? Should I have nerf bars welded or bolted to frame? Who sells shoulder harness seatbelts for my rig.
Chad the stock six is tuff to beat as an all round motor-It'll run out pretty good on the road and pull like no ones business on the low end,as far as the nerf bars thats up to you and how hard you plan on using it-4wd hardware sells a 3" round light duty nerf bar that will work pretty good-If you plan on rock crawling you need something hellbent stout that runs under the body from wheel well to wheel well and also protests the rear overhang-this would be a custom job to get that-as far as bolting or welding either would work,bolted makes them easy to replace or remove at a later date-a lot depends on what you can afford to spend and how much of the work you can do your self,tools,knowledge,shop and experience can go a long way to keeping the cost down-good luck with your rig and here is a pic of my "nerfbars"-keep in mine that i rock crawl and these would be overkill for most rigs-JC
