Weldable steel?
My guess id that it is not painted. If painted you have to burn the paint in order to get an arc for welding. My 2 cents worth....
SC
It's just marketing BS, it's mild steel.
scott anderson said:
Lowes is a very expensive place to be buying steel...
i wasn't buying it there i just happened to see a "weldable steel" sign and was wondering.:confused: :confused: :confused: Thanks John for sheding some light.
fisherman said:
i was in Lowes today and saw "weldable steel" What makes seel weldable?
The wife says it's cruel to weld on seals, they scream and the ASPCA and PETA get all over you about it. Also, it stinks, and it's a pain to find a decent ground on the damn things... I've HEARD. :o :D
Yeah, "weldable steel" is a gimmick, ALL steel is weldable. I've even welded iron, which is just a low grade steel alloy anymore.
Hmmm. How about some comparisons?
weldable steel?
glueable paper
meltable plastic
paintable wall
edible food
readable book
throwable ball
flexible spring
and the best one?
Trail Rated Jeep :eek:
As Robin Williams used to say "If you look in the dictionary, under redundant, it says 'See Redundant'."
:p
you sure it wasn't wieldable steel........
this type usually has a large metal stabber attached to some type of handle......
usually found in the ninja supply section near chaulking.
Aaaahhhh! I have heard of this!
It's called a screwdriver, right? And it tends to enter your flesh when a rusted-tight screw head pops off, applying all of that torqueing motion and arm leverage to shove the end of the screwdriver halfway through your palm (or other appendage)!!
:D
