Welders - Need advice
Stouttrout
Registered Jeep Nut
Sour Lake
Tx
I have decided to learn how to weld. Every time I need something weld now I have to go to the guy down the street. He charges me a $10-25 minimum charge. I would never have anything over quarter inch to weld.
Where should I start? What type of machine should I look for?
Dan
Welder...
How much do you think you'll be using this welder? My first welder was a Lincoln Cracker-Box stick welder...The only time I use it anymore is for stuff over 1/4"..My welder of choice is my Miller MIG...It's a Miller 135, it runs on a 120v 20 amp circuit, and will weld up to 3/16" in a single pass. I use a co2-argon mix with it as 0pposed to the flux core wire.
I have about 1000-1200 invested in my setup, but you can find a comparable machine for less. Look at a Lincoln or a Hobart. You'll be surprised how much you use a welder once you get one....You'll be making all sorts of stuff...
If you want to screw around and practice welding, just come on over to Houston and I'll let you practice with mine...
I've got a Lincoln SP175 and really like it. Its 220V. I've had 120V machines and they just don't cut it for doing suspension, frame or heavy fab work. Its a bigger financial commitment but I'd go 220V right away. Also, as your skills progress the 220V welder will be able to keep up with you, whereas the 120V will reach a uasble ceiling pretty quickly.
Maybe you shoudl take a class at the local VOtech or Junior College. This way you could get some exposure to different types of machines and different methods.
In doing that you will decide what thickness of material you will need to weld. If it is mostly sheet metal then choice should probably be MIG.
If it is always thick metal then a cheeper ARC buzz box will work.
If it is going to be a mix then you will need a larger MIG unit that can do both.
If you just want to get started learning, an AC buzz box like the Lincon at HomeDepot/Lowes is an easy way to get into it. Also by learning the more difficult method, you will be a better MIG welder in the future. You can also move onto TIG easier too. As you will know how to add filler rod to a puddle at a constant rate. That can be hard to learn.
Probably best to take a class first. You will learn a lot from that.
Carl
I can't disagree with any of the posts but I tend to agree that a 240 volt wire feed will be more useful and less frustrating to use. It will maintain a better resale value if you decide to sell it. Keep in mind the welding machine is the tip of the iceburg. You will find yourself needing a way to cut metal too. Plazma torch and oxy-Actelene are next. You need a heavy bench with vice and several types of clamps. Layout tools and grinders. Bandsaw and the new drycut metal cutoff saw. Don't forget the fire blankets and extinlishers. I am sure you have all the hammers and drills and handtools already. Now in order to justify having all that stuff you will start more projects and you find you need a tig welding machine. You will become a tool junky. You might be better off paying the 25 dollars per tack .:)
