Welding aluminum advice?
jeepdreamer
Colorado Springs
CO
I've been wondering about learning to weld aluminum..I know that TIG is the preferred method but I have a MIG and was thinking of getting a spool gun. Does anyone have any experience or input that would help me out here? I can Mig Steel pretty well but have never tried this. I won't be making anything that is structural or that needs to be pretty...nor will I need to weld two beer cans together....haha. But any advice would be great...Thanks all!
First off let me say that I was never able to weld aluminum myself, even in class with an instructor but a good friend who was a tool and die maker by profession and another friend who was a prototype machinist both told me that one of the biggest problems with trying to weld Alum is that there is no color change as it heats up, it simply goes from solid to liquid without a lot of warning. I also know that if you do weld with tig you have to ball the electrode tip rather than sharpen it as you would with steel. I never talked to anyone who had a lot of success with trying to mig it, but that doesnt mean it couldnt be done and done well, they just had tigs rather than migs available.
So, I know nothing of value for you but posted anyway!
havent welded aluminum myself, but welding two cans together would be excelent practice!!! cheap material to practice on too!!
I've always wanted to weld aluminum too, but cant justify buying a tig right now.
sorry i cant help either...
I also have never used an aluminum spool gun but I have done quite a bit of TIG though. Shoot, for the money that the Heliarc machines are going for now in this economy, you would be better off getting one of them instead. The biggest issue I can see is having control of the heat. When you get started welding, you have to allow iyour material to pool before you put any rod into it. But as you weld, the metal gets heated more and more. So as you get closer to the edge of your material, you need to back out of the throttle(heat pedal) to control the melting metal. If you can not pull back on the heat, then you end up burning a notch in the end of your material. I would thing that the spool gun would be tough to get enough heat into the material to actually allow it to fuse together. Of course I have not used one though so who am I to say...LOL
A friend and I built an aluminum bass boat about 10 yrs ago all welded with a spool gun. He is a welder by trade. He tried several time to get me to try to weld some of it but I did not want to. He sure made it look easy. It was all 1/8". He said that once you get your machine set right, it is just like welding steel. You just have to keep moving. One thing that always stuck in my head that he said is to always get a good quality wire. Do not scimp out on this cause you will have nothing but trouble with it feeding.
Just my 2 cents.
