Hello All, been lurking a while, learning about my favorite Jeep I had never owned. I ran up on a pretty good one in S. Arkansas and ended up bringing her home:
Other than the lift & bumpers, she is pretty much original. 1982 model, 6 cyl. 4 speed, ps, manual brakes. Original paint, no bedliner anywhere, good interior, tilt steering. Everything except the speedo works.
Really Good frame, no rust at all that I can find, body mounts very good, just a few minor rust spots starting on the not-perfectly-straight body. Biggest problem is in the back = the original owner pulled a small boat, and had a habit of setting his battery for it in the bed right in front of the fenderwell at the bulkhead. Well tilting the battery caused a little acid to get on there & now there is a nice hole to fix. I have a post in the body repair forum, but if anyone has a source for replacement rear fenderwells feel free to speak up!
Plans for the rig are to go with a Cummins 4bt turbodiesel & 5 speed. I will swap out the stock axles (since I'll need different gears for the diesel) and will probably use late-model ones w/ rear discs and driver's side chunk. But that will be after I get all the rust stopped/fixed so I'll just enjoy it as it is for awhile.
