What can I do?
OGRES
Ramblin' Wreck
Suwanee
GA
So I sold the Scrambler several months ago (:mad:) and bought a 2002 Land Rover Discovery II (I know, I know...I shouldn't have done it). Well, the thing has some issues with it that the dealer promised to fix. The dealer attempted to have the issues resolved once, to no avail. I am in the process of scheduling to have the issue fixed (hopefully) once again. In the mean time, the dealer tells me that the vehicle will perform as it is supposed to, even with the issue that I am having (the three amigos for anyone in the know).
Well, I went trail riding the other day and basically was running with one wheel drive because the dang electronic traction contol doesn't work (I found this out as I was unable to cross a small washout where I lost traction on the driver's side front wheel and it was the only one spinning).
So I am pretty upset about the fact that I have a Land Rover and can't even take it out on some basic trails. What kind of recourse do I have with a used car dealer? In my paperwork, they promise to fix the "three amigo" issue. If they don't fix the issue, do I have some legal rights to persue due compensation or return the vehicle? There are lemon laws for new vehicles, but what about for used ones...at least from dealers?
A quick Google search for "land rover discovery ii problems" yielded almost 2 million results while the similar search for "jeep scrambler problems" only returned about a half million returns. What you do with this priceless piece of information is up to you, but I know what I would do.
If you have it in writing, you have recourse. But depends on the dealer as to how much recourse. If he is reputable, he will want to fix it so you will not bad mouth his reputation. If he is just trying to placate because his mechanics do not have a clue..... Ask if they do not fix it this time if it can go to a dealer ON HIS DIMES! :banghead:
http://www.roversnorth.com/forums/showthread.php?t=1209
tempestv8 said:
The best way of avoiding the 3 amigos is to use the HDC every once in a while so that the valves get "exercised".
Find a steep driveway somewhere and put the vehicle into low range and 1st gear, and turn on HDC so that it activates the ABS modulator and gets it "working".
Most vehicles suffer from the shuttle valve jamming on the ABS modulator simply from lack of use.
i know a guy that has 3 discovery IIs. the joke we make is that he needs to have 3 of them to have at least one running at all times. in reality he has one he dds, one he has as a trail rig, and the other i think he is looking to unload due to some issues he is tired of dealing with.
I knew I was going to have some issues with the Disco, but I didnt' realize how many potential problems there are associated with those vehicles. I had done some research on them, but clearly not enough before I bought it.
Update to the situation: The dealer has purchased some new parts to help remedy the issue. I am having them installed next week. Hopefully this does the trick and I can get back out on some trails. If not, then I am going to keep hounding the dealer to fix the problem so I can at least try to sell the dang thing and not take a loss on the sale.
The real problem is that there is a Scrambler calling my name close by ;).
I've been junkin' at some of the local U-Pull-Its lately and can't believe how many Discos are in there. If there's a particular part you need I could look the next time I'm out there, but hopefully this dealer will make it right. If you have it in a signed agreement from the dealer that they were going to fix these issues, it's enforcable in court. You could also file a complaint with the BBB. If they're reputable they'll care about that. If not, small claims court may be your only recourse. I'd also imagine they license car dealers in your state, perhaps you could file a complaint with the licensing authority (assuming this guy was licensed). I bought something off a shade-tree "dealer" once and regretted it the minute I started poking around in the thing, but you live and learn and hopefully never make the same mistake twice!
Tell that to my wife!
You are on yur own there Ogres! I have found can't tell a wife much, but ya can ask (or beg as the case usually is!) :banghead: :evil: :woot:
Fortunately I have a good one that does not give me too much grief (or hasn't found all the stuff I bought yet!) :D
