What is the best rust proof for a frame?
Flatie46
Russllville
TN
What is the best spray, brush on or magneticly charged particle way of rust proofing a Scrambler frame? I'm talking is it POR15, Chassis Saver, Epoxy Prime an Paint, Powder Coat, Undercoating, Voodoo Doll, or what have you? Opinions, observations, notions and all welcome. Thank you so much for taking the time answer this post.
I believe galvanize . but Arizona is the best option but its not that cost effective tho.
Sent from my SPH-L900
I'm in the process of coating my frame any day now. I considered galvanizing but it's expensive and I hear there are many problems with it such as poor paint adhesion, warping of the metal, and excess material collecting all over it. My frame was newly POR 15'd a couple months back by the PO but I'm sandblasting it Friday and going another route. I found something a little better. Forum member "surfjeepzx" did a full ground-up restoration and used an epoxy primer that looked great. It's by southern polyurethanes based in GA. I did my research and it's one of the best, like impenetrable. I even called the guy and explained to him my concerns and mentioned POR and he reassured me that this stuff is way thicker/way more durable. I have a couple cans coming next week so I'll let you know exactly my thoughts.
Also, if you're concerned about salt corrosion during the winter months (which I really am), I'm doing a process called Waxoyl. If you've never heard of it, it's basically a hard wax coating that they spray through the frame rails of your car only one time that dries and hardens and makes a permanent bond with the metal to seal in everything so that water can never penetrate. Their claim is that it "bulletproofs" your car, and I've seen loads and loads of classics go in and out of the licensed shop that does it in the dead of winter with salt all over the roads and so far haven't heard any complaints! Hope this helps
I used Dupont ful-poxy 491-16 on my the bed floor pannels I had made and a couple other patches. I hope it's good stuff, it seems tuff. It was all new sheet metal so there wasn't any rust to be removed. It stressed in the directions that the metal be clean. As in any time you deal with rust I hope to get it all gone but with a boxed frame and so many cracks an crevaces there's alot of places I could miss or not get to properly. So I wasn't sure if the epoxy would be good or if more of a coating like the por15 or others would be the trick.
Galvanizing is best. Epoxy is next best. I have two work trucks that i used epoxy and then painted with enamel. On the first one I didn't put enough paint on and wet sanded through the paint, but didn't break through the epoxy. I've driven the truck for the last two years (including winters) and have had no break down or rust through the exposed epoxy. The epoxy I used was kirker brand. I've heard only good things about kirker and spi's epoxy. Which ever you use, follow the directions. Epoxy's have a window after sprayed that they can be top coated. Outside that window you have to sand and then top coat (many recommend to reshoot a thinned coat, then top coat. I found out about all this two late for my first frame. On that frame I acid dipped the frame then used a enamel paint on the inside and outside (lucky it was a frame that I welded patches where pin holes were found after the dip). On the good frame I acid dipped and then sprayed epoxy inside the frame and on it's outside. Then I sprayed the inside and outside with enamel. Spi has a website along with another (Autobody101.com). Both have a ton of information and the guys are helpful to new guys. If you search epoxy primers on these websites you will get a lot of information.
