What is this connector supposed to go to?
In my 81, there was a reverse light connection that hit a relay fed by the oil pressure sending unit or something. That way the reverse lights only came on when the vehicle was running. Every so often the topic comes up here and is quickly forgotten.
In my 81, there was a reverse light connection that hit a relay fed by the oil pressure sending unit or something. That way the reverse lights only came on when the vehicle was running. Every so often the topic comes up here and is quickly forgotten.[/
Ok so I had a chance to look and my reverse wire was disconnected from the transmission (they now work) and no open connectors on the oil p sending unit. Still a mystery. I appreciate everyone’s brain power though?
I’ve got the T5 and my back up lamps don’t work....
there's a wire harness for that on top of the tranny which is usually the culprit. was for me at least.
see if you can access thru the shifter access panel
