looks like a oil pressure sensor wire hanging down, not a really good pic.
how about one from inside the hood near oil filter and one under the body pointed up
There is a little nub on top of the shifter bracket on the Dana 300 where this plugs into. real hard to see unless you go through the top, but pretty easy to feel. Should just pop back on.
The wire just pushes on like a spark plug wire. I'd try cleaning all the crude out of the housing and off the post, then squeeze the housing with a pair of pliers to close the gap in that metal ring in the center, then push it back on.
You need to clean the crud out of the cap and from around the sender. There is a lip on the sender that the rubber cap will snap into. Right now the rim on the cap is filled with Oil and Grit. Get a little dental pick to get stuff from under the lip, same with the groove on the outside of the sender. Also try to blast the contacts clean with carb cleaner. That will get all of the old oil out and help make a better electrical contact.
Once it is all clean it should snap on top.
This area is real bad for having dirt and oil slung up on to it, and eventually this wire will come lose. Not a big issue and an easy fix.
