what mig welder to get??
Scott2112
Hiram
ga
All,
I recently sold off some parts and raised enough to purchase a welder which Ii desperately need at this point. I was certified to weld tig and mig in my USMC gunsmith days, so using it is not a problem. here I what I need to know: what is the best bang for your buck welder set up that does wire feed (mig) and maybe tig?? I have an available 220v outlet next to my garage as my dryer is gas powered. So it can run off 220. I wouldl also like to weld 3/16 plate or thicker, is that possible? i don't really have any brand preference, as long as it is not a cheapy, however, i would like ot keep the cost under 600, (working welder unit only) is that at all possible?/ thanks, I really don't have the time to do research as college calculus is taking up mos tof my time. this welder would mainly be used for bodywork and bumper/cage fabrication, but I have a feeling that once I own it more uses will pop up. thanks
Scott
Look at a hobart handler 140 its 110 unit and works great. Its under $500 new. I think its $419 at Tractor supply. I have used my buddies 135 handler the model that was out before the 140. As long as you know how to weld. You can weld up to 1/4" easily. I bought a used L-tec 130 on ebay for $250 and its 110 and 220. I am using it on 110 till I get 220 in the garage.
HTH
Mark
TIG and $600 is pretty much an imposibility unless you know someone or are scratch starting a unit that has been added to a Tombstone welder.
I was going to reccomend a Millermatic 210 since you were wanting to do heavier welding. You can probably get by with a MillerMatic 175 or a Lincoln SP175+ Make sure to get the plus not the "T" version as it allows infinite voltage adjustment. As opposed to a tapped transformere that only goes up in solid increments.
Check e-bay for the best prices. There are many welding shops on there that price stuff shipped to your door. A good internet supplier is Cyberweld.com they always seem to have pretty good deals. Hobart and Miller come out of the same factory and use pretty much the same parts, but the quality of parts seem to be a bit better on the Miller. ie miller uses copper transformers while Hobart uses aluminum, drive wheel on Miller are aluminum while Hobarts are plastic. Now for home use you might be able to get away with the Hobart. But for long term use go Miller or the Lincoln.
I have models from each and do not really prefer red or blue. Often it comes down to what each manufacturer has in the particular amp range that you are looking at. But let me tell you that there is a world of difference between the 175 machines and the 210 machines. A whole world. But you might try going up to the Miller store, I think that it is up in Norcross. From time to time they have demo or used stuff at great deals.
Carl
if you buy a 600 dollar welder you will be disappointed...but for about 700 u can get the millermatic 175....i think that is the best in the range ur talking..but it is not near the welder as the 210 ...for one thing you have to use those tiny 11lb rolls ...and the per pound price of those rolls is crazy...just my $.02... course i just bought a 210 monday..so i may be jaded a bit:rolleyes:
Carl
I agree with this. For MIG, I run a Lincoln SP175+ and really like it. I lucked out on mine. My welding supply shop had it half price because UPS had dropped it and scratched the paint.:D Perferct machine with the full warranty. I then added the cart and tank/gas, extra wire 35 and 30, tips, nozzles, extension cord, auto dim helmut, apron, etc. By the time I was done I was at $1000 with my "deal"
It adds up quick.....
I hear the new Hobart Handler 180 is a nice unit and can be had for right at $600 (Harbor Freight with 20% discount) or online (Cyberweld, etc.)
I have a Clarke 180EN/220 and I'm very satisfied with it. It will weld just about anything you'll want to weld in your garage and I paid $580 for it, with a Cart, many tips, large roll of flux wire, gloves, brush, auto hood and a half jacket.
Got it from the Welding Depot http://store.weldingdepot.com/cgi/weldingdepot. It runs gas or flux.
If I was going to use it to make a living I would have spent more but for the money and usage you cant beat it, its a quality made machine. Right now they have some very nice package deals going on, worth checking out. If you call over there ask for Mike, that is who I have always delt with there and he's a pretty cool guy.
I don't have any direct experience with this outfit, but thought you might be interested in this link:
http://www.pirate4x4.com/forum/showthread.php?t=440934
I bought a "used" Millermatic 175 (220V) welder from some guy selling locally in the "Trading Post" advertisements. It had only been used one time, looked brand new, and came with cart, extra tips, wire, and regulator. I did have to buy a tank for it. I looked around for a couple of months before I found this one. Can't remember exactly how much I paid but I think it was $600.
Most of my welding so far has been on sheetmetal and a little 1/8" plate, but when I welded my d-rings to my trailer, I got to crank the welder almost all the way up! That was pretty cool, as I got to see just how powerful it was and REALLY burn some metal!!:D :eek:
If you can swing it, go for the 220V. It gives you a little more flexibility. I'm very happy with the Miller that I have.
dream machine
I know this is a little out of your price range but it looks like what everyone would like to have in their garage. It is a welder that does it all. It will arc weld, tig weld steel or aluminum. It will also run a wire feed unit. To do that you must have a Constant Volt/Constant Current machine with high frequency. This CC/CV unit will also run on 220 single phase or three phase input voltage. Check it out. http://www.mylincolnelectric.com/Catalog/equipmentdatasheet.asp?p=5383
