What to look for when buying a scrambler
60thjeep
Presque Isle
ME
I am trying to find scrambler to buy, but I really don't know what to look for when buying a vehicle this old. I found one, but I thought the frame looked a little ruff. What should I expect the frame to look like? It had a lot of surface rust, no holes, but had what looked like cracks in the back.
What else should I look for?
If anyone knows of a scrambler in New England for sale, let me know. I don't mind somewhat of a project, but don't want a total restore.
Thanks for the help.
The usual Jeep spots - around the tub supports at either end of the door openings, the seams around the rear wheel housings, under the fender flares. As you've already noticed, the back of the frame, and at the rear spring perches.
After that, it's a matter of equipment. Keep in mind, they've been around a while, so there's a good chance all sorts of things have been swapped in and out. Finding one with all of the original pieces, that's still in nice shape, is getting tougher all the time.
Consider looking further than New England. A car shipper is a lot cheaper than major repairs, if you find the right one. Or, consider a one-way plane ticket and have an adventure getting it home; others here have done it. Jeeps out of Texas and the Southwest seem to have a lot less rust issues. You may get lucky, it just not as likely up there.
If you look out here in California you'll find a lot of rust free rigs. Some of the guys out here will probably check it out if it's close to them. Shipping will vary depending on who you use but much cheaper than fixing rust issues.
How much do you want to spend
Alot of your decision will be based on how much money you are willing to spend. Make me an offer on this one.
Just kidding. There are alot of good Scramblers out there. I am in Colorado and my jeep was a Colorado jeep. The frame is all that is left of the stock jeep and it was virtually rust free. You should definitely look for one from a desert area.
Good Luck Butch
Thanks for the info. I will broaden my search area.
Is the frame the only thing I need to worry about or are there other problem areas I should look for?
Also, check out the front floorpans. They're quick to rot out. On the exterior, look for signs of bondo/rot under the "Jeep" stamping in front of the doors, and also the lower rocker right behind the door. Both of these areas have supports on the inside of the tub that create pockets for dirt/water to sit & rust.
Good luck,
Craig
