What's it worth? '79 Waggy 401
2K1TJ
Still Scramblin'
Rockmart
GA
I know I don't have much info yet, but bear with me till I find out more.
Here's what I know:
'79 Waggy
401 w/Edelbrock intake, ignition mods
rebuilt 400 trans
Q-trac
44 front
offset 44 rear
Body is pretty rusty. It's being parted but I think I can get a good deal on it if I buy it all.
What would be a good starting point, assuming none of the body is salvageable and asuming all the drivetrain is good? I know the desc. is vague, just looking for a "ballpark". :)
I would offer him $200 to $500. Espically if the body and frame are pretty far gone.
If you are lookign to put stuff on a Scrambler then the 401 and Transmission are good. The Steering column could be used. Also the front Diff woudl be good. But the rear offset diff would need to be cut and centered if you really wanted it to be right.
However if the frame is good and it is only the body that is bad. Then you could trash the body and mount a scrambler tub and front clip to it. Wheel base is about the same and you would have a pretty heavy duty scrambler for not too much work.
If that would be your goal you might go as high as $1k but the useable parts would really need to be in great shape.
I woudl suggest showing up with cash in hand. Also if the seller's wife is within earshot when you make the lowball cash offer you stand a better chance of walking away with it. Now I know that is a little underhanded, but if you are looking for a bargin...... You might want to pull out all of the stops.
Carl
i got one with a 360 400 tranny q track etc... i paid 100 dollars for it ..but it was not running....i am going to part it out...if u need anything off this truck let me know...i was told(dont know if true)..that with the quadratrack that the axles had some sort of a locker in them..i am sure someone will straighten me out on this...
Not real sure what you want to do with it, but just incase you are looking to do a restore, or fix it for a driver, the 401 is a transplant, 78 was the last year for the 401 in the Waggy (wish I still had our 78 Waggy). Check out ifsja.org, the international FSJ Association. They have a pretty good forum there and you may be able to look in the classifieds there and get an idea of price.
Robert
Thanks for the replies.
Anyway, the 401 is gone :(
I mainly wanted it for the front axle, possibly the engine and trans. But I probably would've just taken the front axle and sold the engine/trans to make most/all of my money back. Doesn't look like it'll be possible now though. I'll still make an offer on the axle though.
BTW,that's a good tip on the (un)availability of the 401 in '79. I don't know much about FSJ's. Wonder if it really is a 401, or just a 360???
