whats the best way for the softest ride
OK, I have taken ALL advise here, & combined it with some more research, at this point I am going to try the Rocky Road Outfitters, CJ to YJ spring conversion kit, (which will come with All new bushings, brackets etc...), because it will prevent the nose dive effect that the shackle reversal kit gives, & it is entirely greasable as well, then I will get with Alcan for some custom springs & we will see what we end up with!! I tend to agree that my springs are probably SHOT.
thanks to all who responded!!!!
Rich
I used the "Rocky Road" YJ conversion and the length of their shackles causes a loss of caster in the front and the steering will be more skiddish. I don't like their service and their attitude and wouldn't purchase anything from them again, but that's for another time. I did replace replace their conversion with a "MORE" shackle reversal kit that welds the shackle mount in the frame. Very good set up, but you will need to address the front drive shaft.
OK so sounds like I'm back to a shackle reversal kit, seems to be the most popular choice on here, the Alcan springs seem to be a good option, maybe shackle reversal w/ alcan springs??
Most of that issue with the caster problem can be cured with a set of Steel Shims once everthing is back together and you can get an alignment shop to tell you how far out the axle is.
Probably looking at a 4 to 6 degree shim. Figure $40-60 for the pair of shims.
If you want to go for it while replacing the springs go ahed and order a set of 6 degree and see how they come out.
If you have the cash and want the YJ springs I would suggest the Rubicon express or a nice set of OME springs. I think it is Quadratech that will put together a complete OME conversion kit.
Carl
Has anyone tried using Grand Wagoneer springs? They're longer and should ride smoother...
Or use custom packs from National Spring- alot of thin leaves, super flexy, but expensive.
Best trick I've ever seen is putting nylon strips between each in individual leaf, it's an old street rod trick to smooth out ride. NAPA sells it in bulk rolls.
I'm still having a problem with the 35's and stock susp. Hope you can confirm that before you order another stock height susp.kit.
I only need better brakes, I put A massive booster setup for hot rods, it works good, but no stop on a dime action, I'm saving for the vanco set-up & eventually will do some type of disc rear, I'm just trying to get a better ride, my ride is actually better with the bigger tires, I haven't noticed any NEW problems, what kind are you having? if you have a stock susp. do you just have a body lift? can you post pics of yours? I would be interested to see another version!!!
I meant that I find it hard to believe you can fit 35's under a stock suspension. Looking at the amount of open space above the tires. Must be the missing flare illusion.
I've only got 33's with a 4" SL and 1"BL.
Oh I got ya!!, yes you have to consider the flares drop down what 2-3"!!, that will make a big diff in the look, it will make the tires looked tucked, better than cosmetic surgery!!!, as far as the "extra" room it looks like I have keep in mind, the added diff. between the top of a 33"& a 35" in the fender well is only an additional 1", the other is @ the bottom, the flares will go on this week, for now factory
CJ8 5" flares, when I have the time, the TJ flares post surgery, (after the fenders are cut)!!!!
